Traveller 5w30 or 10w30 full synthetic in Tgdi
Hello everyone . I have get some Traveller full synthetic for $4.99 or 6.99 10w30 and 5w30 both is sn plus or SP. I want used that ford 2.3l eco-boost engine . 4-6k miles oil change . We check tractor supply website it need ford spec for 5w30 grade on bottle it did not have written the ford spec .
I use there marine grease but not firmilier with there oils.
Looks like Warren makes it. I assume it's same as supertec. Amazon, costco ect
Ford spec says 5w30 api sn also works for the 2.3 - sn+ and sp are upgrades on the old sn spec so what you have will work fine.
I believe it’s made by Smittys Supply … Smittys makes Cam2 has well.
The 5 qt containers are a dead match for Cam2 5 qt containers…
That oil should be just fine for a eco boost motor. API SP means it has been tested for LSPi.
The Traveller 5 qt container picture is the same exact container has this one. And I have checked in the Tractor Supply store near me and it has SSI underneath the container. Smittys Supply Incorporation.
I am confused because websites wss-m2c945-A but on bottle it did not say anything that it meet spec of ford. Just api an plus or SP.
