dnewton3
Staff member
You can run the cheapest oil out there for an oil change it, however unless you do a used oil analysis you don’t know how the oil is doing. Many people say they run this without any issues and yet their wear rate has increased, varnish build up, or etc yet it “ran just fine” without any data lol.
For example. Both ran just fine. Yet wear rates was drastically different.
I'll apologize in advance, because this will come off harsh; not meant as a personal offense.
There exists some really flawed conclusions in your logic of this post.
- such a young engine should not be viewed as anything but exhibiting break-in; it is completely unacceptable to attribute any "wear rate" to a lube here. There is no ability to understand a wear-rate when the variables of machining remnants and use factors are completely uncontrolled and unknown. It is absurd to even talk about a "wear rate" during break-in. IMO running a used oil analysis during break-in is a complete waste of money and mental effort.
- it is wrong to run a single sample of any lube and make conclusions about wear rates relative to another lube; the data is woefully lacking in magnitude sufficient enough to understand ranges and variability in regard to wear
- you cannot use small sample sets to properly determine how the wear is doing other than to compare/contrast to known (proven) averages, ranges and stdev's for the same lube in the same application
- singular used oil analysis can inform us how the lube properties held up (vis, FP, etc), and we can see undesirable things like contamination (fuel, soot, oxidation) ...
- singular used oil analysis can ONLY be used to compare/contrast against proven historical macro-data, statistically analyzed, when all the other inputs are identical or properly controlled
This just continues to prove that many folks here have ZERO understanding of the used oil analysis as a tool; what it can and cannot tell us, the benefits and limitations, and how to properly use it.
