Yes. That’s extremely similar to the definitions I’ve understood for years now.From what I remember:
- Detonation/knock is the fuel mixture unevenly combusting or only partly combusting. You get an uneven flame front or an exploding event/rapid uncontrolled ignition, but it's typically still initiated by the spark plug.
- Preignition is the mixture igniting before the spark plug fires, usually due to combustion chamber deposits. Engines that would "run on" were effectively running due to preignition.
I think they DO often get lumped together however and it could be argued there's some crossover.
With LSPI, you have the mixture igniting spontaneously before the plug fires, and due to what is generally high load (so lots of fuel + boost) and the position of the piston/rod in the stroke at the time (probably approaching or at TDC at the time of this violent eruption of the air/fuel) it will often completely destroy the piston.
Violent detonation can also crack/damage pistons, even if it's initiated by the spark plug.
I used to see what resembled ball peen hammer strikes to piston tops on engines that suffered preignition. We used to associate preignition with a “hot spot” in the combustion chamber igniting the mixture before the plug fires & detonation as too low of an octane being used. The results were the same so verbiage interchanged
The only difference I’ve heard about with TGDI engines is they’re more sensitive to oil additive chemistry than the MPI engines.
