OVERKILL
$100 Site Donor 2021
Mercury and Volvo buy Chevy blocks and build their own engines with them. It is not a GM engine, only a GM block. So what works in a GM 4.3 engine has nothing to do with what might be appropriate in a Mercury 4.3 engine. I do not run mine hard like many do so I have sometimes use 15w-50 full synthetic. Whether that is a dumb idea or not only time will tell. The engine is only 14 years old. I change the oil once a year since it does not get a lot of hours on it.
I believe some of them are based on marinized crate motors as well, or developed in part with the OEM in question. I say this because some of these "packages" share names with the OEM. Most of them, it's a lot more than just the block that's OE too, for example the Mercruiser 888 was a Ford 302 lopo (non-HO firing order) with car heads, Ford distributor, Ford 2-barrel intake and a Holley 2BBL carb. I assume the cam was a custom marine grind, but most of that engine was just standard Ford stuff.
The PCM GT40 in our '95 Supra appears to be some sort of marine Ford crate motor, has GT40 heads, GT40 intake, EEC-IV ECM that's always in open loop and uses all OE Ford sensors for everything. About the only thing marine specific are probably the camshaft and the exhaust manifolds.
