Along with "flow lubricates" and monograde oils being "horrible" for your engine, cold startup wear is never an issue. Every grade has sufficient viscosity at cold startup to provide more than an adequate MOFT.
MOFT always wins. A 20-grade oil will provide an adequate MOFT under most circumstances in everyday driving in your vehicle.Ok, so 90% of engine wear occurs at startup is not true. And, flow is not required for a hydrodynamic journal bearing to create a separation force. You just need viscosity. Got it.
My car specifies 0W-20. This must be the tree huggers trying to give me better fuel economy at the expense of wear. Should I run 25W-40 in my Lexus? I actually do drive this car hard, like a boat.
Not everything you read on the Internet is correct is it?Oh oh, just saw those thick vs thin threads below. Now I am confused again. Here is a quote:
“It is time to introduce the concept of lubrication. Most believe that pressure = lubrication. This is false. Flow = lubrication. If pressure was the thing that somehow lubricated your engine then we would all be using 90 grade oil. Lubrication is used to separate moving parts, to keep them from touching. There is a relationship between flow and separation. The pressure at the bearing entrance is irrelevant”
That’s not at all how hydrodynamic lubrication works. Plenty of information available about how it does work if you want to learn.True dat. I wonder why they call journal bearings “hydrodynamic” if they don’t use flow for lubrication. Maybe its cause they spin. And engineers thought it sounds cool. Alrighty then. Thanks everyone!
Coolant temperature is not oil temperatureHi Bob,
My 4.3 L mercruiser specifies 25W-40. But, the 4.3L Vortec in a GM car specifies 5W-30. I assume the Marine version has the same crank and bearings. It actually runs a lower coolant operating temperature than a car. So why the big change in the viscosity requirement?
Yes, that's probably why the thermostat is a lower temperature, since the coolant is the only thing helping to cool the oil, since in a passenger car the engine isn't normally subjected to such loads the block really isn't meant to keep the oil cool at WOT for extended periods so in marine applications the compensate by keeping the coolant at a lower temp is my guess, I don't really know that for a fact, kinda like how on the street you'd run 5W30 in a Corvette but on the track you'd run 15W-50 because when you run the engine at WOT for extended periods of time the sump temperature is significantly higher than it would be just driving around the streets.Pretty obvious statement. But let me state what I think you mean...oil temperature is hotter in a boat than a car even though the coolant temperature is 20F cooler. Its because it’s driven at much higher throttle positions for longer periods of time. Therefore, grade 40 is specified instead of grade 30 to achieve the same oil film thickness as the car engine.
Did I say that right?
Please do a Reply (which quotes your source) so we can determine the source of your statements and to whom you may be responding.Oh oh, just saw those thick vs thin threads below. Now I am confused again. Here is a quote:
No you dont, your car has wheels, your boat doesn't yet the engine still has to move it.Should I run 25W-40 in my Lexus? I actually do drive this car hard, like a boat.
Considering your off-base comments in this thread about flow and what hydrodynamic lubrication means, I don't think I'd put much stock in your suggestion here.Thats what I run in my boat too. 25w-40 is just stupid. Its pretty obvious that Mercruiser gets a cut for pushing that oil. Mobil 1 is far superior.
