It does and I should use it more often.Don’t have Auto mode ?
The 4wd button is a software based locker for front and rear axles on 2009 RAV4. Your 2009 RAV is AWD otherwise as FYI.
Yes, he is confusing a differential lock with a transfer case lock. Some of the early AWD CUV's like the Rav4 and even early Rogues had a transfer case lock - where if you engaged it - it would lock equal power to the front and back differentials and not wait until the system sensed slipping tires. They were still open diff's which are likely enhanced with some sort of ABS traction control. Not sure on the Rav but the early Rogues would automatically unlock at 6mph, so it was really just to get you started.That does not sound correct--when I hear "front and rear locker"
I highly doubt most apartment or condo complex have backup generators (maybe nursing homes do), and especially on 30/F individual condo unit will not have a dedicated diesel generator sticking out in the balcony. It makes no sense at all, as most of the time urban infrastructure will restore power soon (within a day). The local power would likely be rerouted from elsewhere and backup provided by your community, HOA, building, etc instead of your own.Interesting analogy. And the answer is "yes, definitely."
Not sure what you mean by "install" but to me, backup power in a city would be even more important than in the country. Lots of apartment buildings have their own backup generators. Even so, if my apartment had either a balcony or garden, I might consider a propane powered generator and as many 20 lb tanks as I could manage. More likely, the biggest battery backup(s) I could get. Preferably a power wall or similar.
But I'm the type that always wants to be prepared for contingencies. That's why my vehicles have AWD or 4WD.
Yeah, most 2WD cars with open diffs are going to do much worse. I’d still rather have a 2WD with LSD and snow tires probably though (depends on car). AWD might get you going but it’s not gonna help you stop.I guess its better than most 2wd would do... Even my old Tracker with real 4wd would struggle with the loading dock situation as it had open diffs and no traction control(dragging the brakes manually does work). But yes, they are made to perform on real roads, not off road with one wheel in the air.
In snow at low speeds, even CRV AWD with all season tires will climb grades that 2wd with the best snow tires won't.
Look at this “stellar” AWD performance.
The majority of awd systems are actually awful and don't work in time like in rain and snow.
This1. Never had a wreck - decades of driving
2. Driven in many places/weather
3. Prefer AWD/4WD
don’t like them? - just save the pompous attitude and money
Same man. A whole lot of get off my lawn and "I'm such a amazing driver but everyone else sucks so they need awd"energy here. Really like my awd wagons.1. Never had a wreck - decades of driving
3. Prefer AWD/4WD
I used Auto today and it was great. I didn't expect it to be that good for some reason. Didn't notice it engaging.Don’t have Auto mode ?
There is a lot of mis-info here w/r to part time awd systems like you (and I) have. My Gen 5 Haldex in my Sportgwagen is very proactive vs. reactive. It's applying pressure to the clutch pack basically anytime you touch the gas pedal...the reaction time is momentary. I've logged it many times and I have a video of logging the activity of the awd system but BITOG so I can't post it....you can find it if you go to the video below and look around my channel - please like/sub as always. Also, look at this slow-mo of using a 4K RPM launch control in a ~350hp VW. The front wheel moves maybe 1/8 (?) of a turn before the rear goes. It's a great system. I can floor it from a stop in the rain and it just hooks. I have a "tune" on my awd system b/c after more than doubling my power, the system is torque-limited based on the stock power output. This creates a situation where only about 20-30% max torque I am producting was being transferred to the rear wheels. The tune got rid of this limitation so now at max I can get the 50% the system is capable of. Works great on the track pushing out of turns!!!Ford's FWD based AWD does not work on demand/detected wheel spin (at least in 2017, of which I have a Fusion Sport and 2.0 Eco AWD Escape), it applies power to the rear as soon as load is deemed enough (upwards of 50% to rear, if engine load is high enough from a dead stop). It works fantastic.
My Fusion, with TT 2.7 V6 Eco, tuned for 93 puts out 420 torque (gross) and if you choose, you can floor it from a dead stop in the rain and it just hooks and goes (tires help too, as some of today's top perf tires, like the Mich PS4S, are sprinkled with fairy dust, apparently, and hook up 80-90% as good in wet pavement, as dry, especially when those tires are new) .
Now you can argue all day that is not required, excessive, a waste, etc.... Yet an entire message board based on "oil changes" probably is too, but here we are.......![]()
This one has 1” lift and appropriate tires. But that is it.Interesting the Atlas!
Driver mod > all. I'd like to keep mine once we get her something smaller/more sporty and do tires wheels suspension. It could also tow my wagon...This one has 1” lift and appropriate tires. But that is it.
Don't understand this?Driver mod > all. I'd like to keep mine once we get her something smaller/more sporty and do tires wheels suspension. It could also tow my wagon...
Just that having someone that knows how to drive the vehicle/understand's it's systems/limiations is really the most imporant thing. This driver clearly knew what they were doing and even though the system is not a locking 4x4 type deal, they were able to effectively offroad in it.Don't understand this?
But, with properly executed AWD, these vehicles can do what 99% of outdoorsy people do. We have around 100,000 miles of gravel roads in CO. Most require some clearance and AWD in case of melting snow, some mud etc. That is why Subaru's are so popular here. It is not just bcs. snow.
Ah ok, yes. This is Moab I think. Generally, people doing this are those that know what they getting into. Of course, the issue is that while it did it, that shift in torque can make you hit something if you are not careful. But, again, 99.999999% of people will never come close to it.Just that having someone that knows how to drive the vehicle/understand's it's systems/limiations is really the most imporant thing. This driver clearly knew what they were doing and even though the system is not a locking 4x4 type deal, they were able to effectively offroad in it.
I agree, these soft-roaders should handle most anything average folks are doing. I've rented many many vcehcles over my career and done a lot of offroad driving as a geologist in the field and never had an issue with even the most car-like awd cute-utes getting around muddy/dirt roads, fields, etc. AWD is a must for me in that capacity.
For sure - they come with a street/car grand touring tire basically which is nearly worthless for anything beyond a gravel road. Tires so are so critical - I run the Pirelli Scorpion AS 3 on my wife's Atlas but if it was mine, I'd do an AT tire like a Falken Wild Peak or maybe the Conti AT one (can't recall the name)...most have a livable road ride.Ah ok, yes. This is Moab I think. Generally, people doing this are those that know what they getting into. Of course, the issue is that while it did it, that shift in torque can make you hit something if you are not careful. But, again, 99.999999% of people will never come close to it.
Also, like in everything, the choice of tires is fundamental. I would say all of these vehicles come with some sort of HP tires. I got Atlas with Pirelli Scorpion Zero 255/50 R20. I mean, why? I am trying to sell them and get something more suitable for these excursions. For winter I got a used set of 18" wheels and slapped 235/655 R18 snow tires. I did some 12-14% muddy/snow inclines at Arapahoe Basin, and there was absolutely no drama.
Right now only Honda Pilot TrailSPort comes with Continental TerrainContact A/T, and Atlas can be ordered with that BaseCamp package that includes Continentals like Honda or several other A/T tires.
