I'm going to order some.
13 mm will usually suffice in place of 1/2" (12.7 mm).13mm and 19mm are common fractions in SAE LoL
No idea where it came from, probably older than me. Anyway, it says Buffalo on the stamping, and on the back Taiwan.izzat a KMC wrench? (Kmart Corporation) Bonus they are thin enough to fit the caliper bolts on VW...
Most calipers measure inches in decimals. Not easier or harder to use. I think I bought a used inch caliper with decimals on bottom and 1/128ths on top just for fun. For loosening and tightening bolts and screws I don’t see any advantage or disadvantage to metric. Just more metric sizes, but common ones probably about the same as inch. Lathes etc usually dials are in .001” or metric .01 mm. Or .02 mm as it’s closer to .001” at .0008”.I have used both systems over the years and despise SAE with a passion. Using a micrometer or caliper in inch vs metric is no contest the metric is so simple a chimp could do it and be accurate.
Anyone who has worked in the machining trades for any length of time knows the basic decimal conversions in their head, the same way grade schoolers were taught the multiplication tables.Most calipers measure inches in decimals. Not easier or harder to use. I think I bought a used inch caliper with decimals on bottom and 1/128ths on top just for fun. For loosening and tightening bolts and screws I don’t see any advantage or disadvantage to metric. Just more metric sizes, but common ones probably about the same as inch. Lathes etc usually dials are in .001” or metric .01 mm. Or .02 mm as it’s closer to .001” at .0008”.
It is without any doubt easier to work in multiples of 10. I guess most of the world outside the USA is wrong. The USA is in good company. LOLMost calipers measure inches in decimals. Not easier or harder to use. I think I bought a used inch caliper with decimals on bottom and 1/128ths on top just for fun. For loosening and tightening bolts and screws I don’t see any advantage or disadvantage to metric. Just more metric sizes, but common ones probably about the same as inch. Lathes etc usually dials are in .001” or metric .01 mm. Or .02 mm as it’s closer to .001” at .0008”.
Only three countries in the world use the imperial system as their official system of measurement: the U.S., Liberia and Myanmar
Lets see 1/3 is .333333 and 1/4 is .25 So please tell me how 1/3 is the smaller one???Remember when Burger King introduced the 1/3-lb. burger to compete with McD's 1/4-Pounder?
It failed miserably because 1/3 lb. is smaller than 1/4-lb.![]()
And then you could drop the /16 and just call them by an integer like 2, 3, 4, etc., much like clipper blades.SAE would be easier if they didn't simplify the fractions and left every with 16 as the denominator. Instead of 1/8, 3/16, 1/4, 1/2... you'd have 2/16, 3/16, 4/16, 8/16, etc.
