Originally Posted By: SHOZ
When I data log my Hyundais the temp is in one degree Celsius graduations from the ECU. If I convert that to Fahrenheit on a display,the temp jumps 1.4F to 1.8F when ever the Celsius changes one degree.
Right, but as I was trying to explain earlier, this isn't an issue with Celsius per se. It's an issue with how Hyundai chose to report the data. They could have gone for more granularity, but didn't.
Also, your example doesn't really make sense, unless you miscalculated something. A difference of 1 degree C is equivalent to a difference of 1.8 degrees F. So, if you started with the temp of 1.4F and increased it by 1C, you would get 3.2F.
