Debating using HPL 5W-30 in a 2019 Lexus RX450h that’s used for Uber. But I’m leery of using good oil for that cause - monthly OCIs at 5K. I could do 10K OCIs but given the propensity of Toyota piston rings getting stuck…
Curious, does the oil gets really dark at 5K miles on the RX?Debating using HPL 5W-30 in a 2019 Lexus RX450h that’s used for Uber. But I’m leery of using good oil for that cause - monthly OCIs at 5K. I could do 10K OCIs but given the propensity of Toyota piston rings getting stuck…
He should probably try Mobil 1 EP 0W-20 first and see if it quiets his engine down enough. Though I read on another forum that PUP is the bee's knees, and that Red Line 5W-30 is what quiets engines, especially those that tick. So, he might not be a good candidate for HPL because he won't appreciate it for what it can truly do.Yes... But it was also quiet on M1 EP 0W-20.
This one is a 2GR-FXS, oil has a golden brown hue on the dipstick but drains dark at 5K.Curious, does the oil gets really dark at 5K miles on the RX?
I got the 2GR-FKS, it gets dark under 2k (using 5W30) miles given it is a D4S system.
I could never stomach the price of boutique oils for changes that frequent. Mobil 1, or Pennzoil Platinum, or whatever your preferred brand of "regular" synthetics is, will do absolutely fine.Debating using HPL 5W-30 in a 2019 Lexus RX450h that’s used for Uber. But I’m leery of using good oil for that cause - monthly OCIs at 5K. I could do 10K OCIs but given the propensity of Toyota piston rings getting stuck…
Just remember: it is still cheaper than a trip to Jiffy Lube every 5K. They charge $109.99 for 5 QTs of synthetic; additional quarts are $12.I could never stomach the price of boutique oils for changes that frequent. Mobil 1, or Pennzoil Platinum, or whatever your preferred brand of "regular" synthetics is, will do absolutely fine.
Except they will strip your drain bolt, over-tighten your filter and improperly reinstall your splash guard for free!Just remember: it is still cheaper than a trip to Jiffy Lube every 5K. They charge $109.99 for 5 QTs of synthetic; additional quarts are $12.
It's not for everyone.I could never stomach the price of boutique oils for changes that frequent. Mobil 1, or Pennzoil Platinum, or whatever your preferred brand of "regular" synthetics is, will do absolutely fine.
If you like Alkylated Naphthalenes in your motor oil, then the absolute bottom you'd want to settle for is Mobil 1. Of course the "boutique" brands use such expensive materials as Esters and ANs. That's what makes them "special". Especially HPL. You should check out HPL's PDS documents on the various motor oils they offer, and look for that density number. There is a reason for that.I could never stomach the price of boutique oils for changes that frequent. Mobil 1, or Pennzoil Platinum, or whatever your preferred brand of "regular" synthetics is, will do absolutely fine.
Lyft has gotten into the maintenance business, $50-60 for a “synthetic” oil change but for 5 qts and “basic” cars.Just remember: it is still cheaper than a trip to Jiffy Lube every 5K. They charge $109.99 for 5 QTs of synthetic; additional quarts are $12.
Comparing DIY oil changes against shop oil change pricing is hardly apples to apples.You'll pay the same or more at many oil change places for a synthetic oil change. What's going to be better at preventing the common ring coking problem in that engine? Mobil 1 5W-30 at ~10% Noack (per 2013 PQIA report) or HPL PCMO 5W-30 at ~6.5% Noack plus ester and AN for cleaning.
Even here in South Carolina, Jiffy Lube charges $89.99 (+ tax) for a synthetic oil change which only covers 5 quarts. (+$10 for each additional quart) HPL PCMO 5W-30 is $70.16 for 6 quarts before the 15% Bitog discount.
I'm well aware of more expensive materials in boutique oil blends such as esters. I've been around this forum for many years and I've purchased boutique oils before, most commonly for a motorcycle application where it matters to me more. For a daily driver, I don't see the gain.If you like Alkylated Naphthalenes in your motor oil, then the absolute bottom you'd want to settle for is Mobil 1. Of course the "boutique" brands use such expensive materials as Esters and ANs. That's what makes them "special". Especially HPL. You should check out HPL's PDS documents on the various motor oils they offer, and look for that density number. There is a reason for that.
A nearly ten year old PQIA report about Mobil 1 of a different formulation than what is on the shelves today doesn't exactly convince me.You'll pay the same or more at many oil change places for a synthetic oil change. What's going to be better at preventing the common ring coking problem in that engine? Mobil 1 5W-30 at ~10% Noack (per 2013 PQIA report) or HPL PCMO 5W-30 at ~6.5% Noack plus ester and AN for cleaning.
When I added the HPL-EC, the low oil warning was on, indicating the crankcase was a quart low. Figured it was a good time to add the EC. The low oil level warning did not go out. Checked the dipstick and was 1 quart over filled. I just left it that way. Oil level sensors (new or used) are unobtainium, as are most parts for a 36 year old Asian import.I just started with SAE40 Engine Cleaner in the Legend before performing major engine work.
I have an under-the-VC photo to compare the results. Not expecting a lot of varnish removal. Just particulate removal.
- Timing Belt
- New Oil Pan
- Replace oil filter case; figure "8" o-ring and cooler o-rings.
- Reseal cam bearing cap.
would you guide me to what i should look for when looking at Density?If you like Alkylated Naphthalenes in your motor oil, then the absolute bottom you'd want to settle for is Mobil 1. Of course the "boutique" brands use such expensive materials as Esters and ANs. That's what makes them "special". Especially HPL. You should check out HPL's PDS documents on the various motor oils they offer, and look for that density number. There is a reason for that.
Good products use results in good results.When I added the HPL-EC, the low oil warning was on, indicating the crankcase was a quart low. Figured it was a good time to add the EC. The low oil level warning did not go out. Checked the dipstick and was 1 quart over filled. I just left it that way. Oil level sensors (new or used) are unobtainium, as are most parts for a 36 year old Asian import.
It's ~250 miles into the "cleaning" and the low oil level sensor (simple float switch) is working again. Coincidence?
