Which has the best detergent additive package?
Mobil Drive Clean?
[ June 13, 2005, 08:46 AM: Message edited by: Gary Allan ]
Mobil Drive Clean?
An HDEO Mixed fleet oil. But although the engine may be clean the Cats may not last as long if you have consumption.quote:
Mobil Drive Clean?
Cats probably won't last as long if there is oil consumption with any oil. Think about it.quote:
Mobil Drive Clean?
PCMO? The one with the better base stocks. Additive levels continue to drop.
True...Good catchquote:
Mobil Drive Clean?
quote:
Originally posted by TR3-2001SE:
I just ran Delo 15w-40 in my Honda accord with 125,000 to clean up after an auto-rx double treatment. I failed to see any cleaning with this stuff after 3000 miles. It is now on Mobil 1 10w-30 and the difference is quite noticable. Much smoother and quiet with Mobil 1. I am somewhat disappointed with the Delos cleanning ability. Auto-rx is the only way I have found to clean an engine to my satisfaction. Oil lubricates auto-rx cleans.
The marketing behind Drive Clean is silly. There's nothing "cleaner" about this oil vs any other respectable dino. In fact Drive Clean only made consumption worse in several cars here.quote:
Mobil Drive Clean?
does the weight of oil help facilitate its cleaning ability and should this be taken into account in regard to the question of which oil will clean best, especially a specific engine? I seem to remember that thinner oil has properties that allow it to do a better job cleaning but I can't remember why.quote:
[bowdown] Well said. My theory is that motor oils can maintain a level of cleanliness, but they are not designed to clean significantly.
we've argued this before to no avail. Bye. [Big Grin]
quote:
Originally posted by JohnBrowning:
Like someone is going to name an oil sludge fest in a bottle.
I forgot,you can even use Supertech dino,just change the oil and filter often.quote:
Originally posted by Alan:
Any ole SM oil in a normal everyday application using sensible intervals.
