All my vehicles require AGM batteries. This would be the Platinum line. Unfortunately, now never available in my area at the Walmarts stores. Usually the first place to check, as appear to be the "best" priced. Previously I have had good luck with them in previous German vehicles. Vehicles now need resetting for the new battery, and if the new battery specs (Ah) are not identical to the installed previous battery, recoding as well. Will need to invest in a higher end scanner with said capabilities when time comes, or go to dealership
Battery shopping and swapping is now getting more complicated. Not convinced the new tech. pays dividends. Usually get at least 7/8 years from AGM batteries, as long as I keep them on AGM trickle chargers when there is an extended down (as in not driving) time.
Incidentally, cost of new battery alone is now between $200 - $250, so pays to give them the required extra care to maximize their life!
