Where to source 90w gear oil?
What kind of mower do you have?
Look into Amsoil or Redline for straight 90. Local farm stores here have straight 90 too. Google says Advance Auto has it. Realistically, an 80w90 would be fine though.
Hi , I did find some and it's very expensive, it's a Kubota mid mount mower deck.
Maybe I should stick with 80/90
I just noticed today the manual states 90w.
Why not synthetic?
Also see if a Heavy Equipment dealer can give you some Final Drive SAE 50 oil.
Usually comes in 55 gallon drums.
90W gear oil equivalent…
My Kubota mower calls for 90w gear oil, seems hard to fine, suggestions?
Do you know if the application requires a GL4 or GL5?
If you can use a GL4 this will work:
https://www.crcindustries.com/api-gl-4-multi-purpose-gear-oil/
If you need a GL5 then you could use Walmart Super Tech 80w90:
https://www.walmart.com/ip/Super-Te...7?classType=REGULAR&athbdg=L1200&from=/search
or Castrol:
https://www.walmart.com/ip/Castrol-.../110374516?classType=VARIANT&adsRedirect=true
Amazon has a bunch of Triax branded gear oils (including a GL4) but none of them are straight 90 weight.
I believe that oil is marketed as EP (extreme pressure). You have a few choices. All these below are mineral (conventional) oils, except Quicksilver which I believe is synthetic blend.
What are the gears of the Kubota?
Does it require API GL-4 or GL-5 oil?
How much oil do you need?
Quicksilver Gear Lube SAE 90 (it's cheapest at Walmart)
https://www.walmart.com/ip/Quicksilver-SAE-90-High-Performance-Gear-Lube
Motul Differential Oil 90 PA
https://www.amazon.com/Motul-111922-Transmission-Differential-Motorcycle
Motul Gearbox 80W-90 (this is very thick oil with MoS2)
https://www.amazon.com/Motul-100099-Gear-Oil/
Liqui Moly 85W-90
https://www.amazon.com/Liqui-Moly-20016-85W-90-Mineral
Usually SAE 50 or 20W-50 motor oils correspond to SAE 90 gear oil. However, not sure about the difference in additive package.
Valvoline SAE 50 mineral
amazon.com/Valvoline-SAE-Premium-Conventional-Motor-Oil
Valvoline VR1 20W-50 mineral
https://www.amazon.com/Valvoline-Racing-20W-50-Motor-Pack
