Why don't you get the Komatsu AXO80 SAE 80 oil?Kubota B6000 calls for SAE 80 oil in the front differential, transaxle, and hubs. Would Komatsu AXO80 SAE 80 oil be good oil for that? It's the only oil I can find that comes in 5 gallons that actually has SAE 80 rating still.
I mostly agree but would never suggest using the "cheapest" of anything unless it was a quality product on a "buy it now" clearance deal. Gears deserve gear oil and there's plenty of great stuff out there to use.The cheapest 80w90 will be fine, it’s not an esoteric moon lander with special requirements, it’s an agricultural machine that survives on neglect.
If you want to go to the multi viscosity 90 route which I'm not sure if it's right, below I listed a few 90 gear oils and can tell you that the Motul 80W-90 of those with MoS2 is extremely thick oil which probably won't work in your case:The cheapest 80w90 will be fine, it’s not an esoteric moon lander with special requirements, it’s an agricultural machine that survives on neglect.
https://bobistheoilguy.com/forums/threads/where-to-source-90w-gear-oil.406251/#post-7579961
It depends what PDS say. It will be way thicker than SAE 80 anyway. See the oil viscosity chart above.80w90 is perfectly fine. No idea what you are on about.
I found SAE 80 gear oil. However, it's neither in 5 gallon nor cheap. It's $25 for a liter.Kubota B6000 calls for SAE 80 oil in the front differential, transaxle, and hubs. Would Komatsu AXO80 SAE 80 oil be good oil for that? It's the only oil I can find that comes in 5 gallons that actually has SAE 80 rating still.
