As of December of 1999 the physical requirements listed on the SAE J300 (a table listing the requirements for different viscosity grade classifications) have changed for the CCS test. The testing procedure has not changed, just the specs required to meet certain viscosity classifications.
The CCS testing temperature has dropped by 5 degrees C for each "W" classification. In addition, the cP max value has basically doubled. (In other words, kinda' of a wash for dinos)
This change was introduced by the SAE to reflect changes in current automobiles. Present day engines will turn over at lower temperatures with higher viscosity grade oils than engines of the past. As a result, since automakers use the J300 to determine which viscosity grades should be used in their vehicles, the specs needed to be updated to reflect new engine technology.
Low Temperature Pumping Viscosity with No Yield Stress did not change.
[ March 18, 2006, 07:58 PM: Message edited by: 427Z06 ]
