What's in your grease gun???
My grease gun still has the last remaining Amsoil purple polymeric gc-lb in it. I use it for my trailer bearings.
The grease gun for the skid steer just emptied its Motomaster lithium #2 blue. Just picked up Federated Co-op semi synthetic Molyguard #1.5.
Omni green grease.
Lots of comments about grease separation and I found that how the gun is stored can make a difference. I took two sections of PVC and made a storage rack, the bottom end caps are not glued so that I can easily clean up pooled grease. The grease seems to separate less and what does leak out is easier to deal with.
Just saw this! Thanks for the pic, i am going to build this, looks perfect!
Are you storing the grease gun pressurized ? Or with the rod back and locked?
Just reading this thread, as i am interested in the Cobalt grease.
Did Valvoline say not to use it?? Isn't Iso 1000 like a 90wt gear oil? Its available as a NLGI 2.
No, a lot thicker
My grease gun finally ran out. When I pulled the tube, I discovered that (for the last few years) I've been using Slick 50 "1" Grease. Supposed to be the "1" grease for everything. It's sorta a green color.
So, in goes a tube of red Mystic JT-6 high-temp.
Schaefer’s 274 Aluminum Complex
Used it for over 10 years. Doesn’t wash out on boat trailers, ATV, very sticky, no leaking from grease gun in HOT Mississippi summers.
I just put them back the way they are when I'm done. It would require longer sections of PVC if I locked the rod all the way back.
Whatever came with those Plews mini grease guns. You know, those yellow tubes?
I haven't seen either around in years. I might have pitched it.
Valvoline Cerulean. Works great, but upon perusing the specs it claims its lowest usable temp is 25° ABOVE zero?!?! That seems MUCH higher than any other conventional (non-synthetic) NLGI #2 grease i've ever seen. Typical is in the vicinity of -10°F, give or take a few.
I wonder if that's a typo or mistake, or if the stuff actually turns to a ball of wax at temps barely below freezing? Either way, my last tube is nearly empty, so I plan on ordering something else. Probably either the Timken or Spicer red stuff.
