What's everyone's favorite 0w-20 these days?
20W-20 was typically a monograde (SAE 20) with a decent enough base oil and PPD's to help it meet the 20W Winter grade requirements. HTHS would have been around 2.7-2.8cP which is probably on-par to what a 10W-30 would have ended up at after the VII's very quickly sheared, due to the quality of them during that time period.
This is part of the reason Mobil had no problem recommending Mobil 1 (which was a 5W-20) for applications that called for an xW-30 back then, because it would have held its viscosity considerably better than heavier multigrades of the period.
Does anyone know the difference between Valvoline 0w20. Advanced silver cap and Extended Protection brown cap. I’ve written to Valvoline and they don’t reply?
I defined the performance drop as engine was sluggish , engine did not run as “free” as while on 20 weight oil and throttle pep was missing.
Confirmation bias, got it. The variation in the energy content of gasoline will change the output of the engine far more than the difference of <4cSt viscosity at operating temperatures.
Gasoline will vary 3-4% even just from winter to summer gas, meaning a 400HP engine may vary ~12-16HP depending on fuel; in contrast, even a Subaru oil pump (some of the highest volume pumps around, certainly for the power density) take about 0.5-0.6HP to turn at full tilt.
That, combined with the fact that we know thicker oils cause less than 1% change in mileage in the real world… well, it’s highly doubtful if somebody changed your oil to thicker or thinner oils without you knowing that you’d ever be able to tell.
I agree with Chris and others. I have noticed loss of response and sluggishness many times when attempting to move up a grade. This was mainly on small engines, light vehicles with MT. Never seen as an issue at highways speeds. Also noticed everyday driving performance loss on various Forester and Crosstrek with the newer FB engine series CVT and MT.
________________________________________________
p.s.: I did NOT notice sluggishness moving up from a 5W-20 on my last Ford 2.0 D.I NA engine. But the oil used was the very special QSFS 10W30 Shell blended for a short while. Why special? Superior base oil blend? Gokhans List favourite? IDK, how many 10W-30 report a -54 Pour Point? - Arco
Since oil temperatures have much more effect on viscosity than what’s printed on the bottle I can confirm no sluggishness, or more peppiness going up a grade or two. Engines are not viscosity sensitive. They have to operate in a very wide oil temperature range. If not those in climate extremes would be in serious trouble.
They still make it. There was just a revision in April. 5w30 is mostly GTL.
IMO Same in name only.
I can't locate the PDS on the shell server, I know FS has changed and the newer version did not perform like the earlier iteration,
So, as T H E C A R S sang in the late 70's ...
It's an orangy sky
It's just a broken lullaby
Bye, bye love
Bye, bye love
Bye, bye love
Bye, bye love
It's an orangy sky
Bye, bye love
Bye, bye love
Bye, bye love
Bye, bye love
PDS stayed the same and was updated 04/2025. FYI> I check yesterday out of curiosity. (y)
