What would you recommend to raise VRP oil viscosity?
I went a bit overboard and purchased 48qts (8 cases of 6qts) of 5w20 to use in my 2016 F150 5.0l and my father in laws 2017 F150 5.0l. 5w20 is the recommended weight. After a lot of reading it appears that a lot of F150 5.0l owners are getting better results with 5w30 and 10w30 motor oils. Helping with valve train noise and retaining better viscosity levels between the 5k-8k mile OCI's. People are saying the 5w20 losses viscosity, especially when higher sustain engine temperatures are involved.
Which got me to thinking about trying to up the viscosity of my VRP 5w20 to say 5w30.
Then today my Father in law bought a 2018 Expedition Max with 3.5L EB engine that is recommended to use 5w30.
Now really wanting me to bump my 5w20 to at least something around 5w30.
What product would be recommended to add with my 5w20 to get closer to 5w30?
I'm great at math so figuring out ratios is easy but knowing what product to use is not something I want to guess at.
I've ready that mixing different oils can actually be more harmful due to competing or incompatible additives.
What would I recommend to change the vis? Nothing. Not a darn thing ...
Do NOT add anything to the oil. You're not going to be able to assure yourself of the desired vis shift unless you run some VOAs pre and post, and by that time, you've spent more money on testing than it would be worth. Even if you add VM, you're altering not only the ratio of the vis, but also all the other additives because you're not keeping them proportional in the overall mixture. Simply put, resist the temptation to play garage chemist.
Rather, sell the oil you don't want to someone who can use it, and then buy some VRP in the desired 5w-30 viscosity. Or, return it for credit and get the other oil.
Oil is a carefully engineered chemical product. Many man years are spent
engineering and testing it before you get a hold of it.
Anytime you add anything to oil.You are throwing all of that engineering out the window.
You should NEVER add anything to an oil.
Many a vehicle ends up in the Bone Yard, because the engine was ruined, because someone puts some snake oil product in the oil.
Chemicals don't always play well together. And anytime you add any chemistry to an oil, there's a good chance that you're going to ruin some of the good properties of ad oil.
You could add Schaeffer EP Moly to it. It will easily raise the viscosity to a Xw30 and at 1pint you wouldn't be overfilling it by much. It actually has additives and isn't just a thickener like Lucas
Best practice is to heed the advice of dnewton3, et al.
But,
As @wlk mentioned, Schaefer's Moly E.P. will increase viscosity and HTHS.
It is/was esterr based I believe.
Circa 2003ish on this form when Moly E.P. was more popular, someone inquired as to what the HTHS would be increased to by adding 50ml/qt (?) of Moly E.P. Molakule provided a rough estimate based on the info provided.
Might have to dig a little to find it, but might be worth a look.
I am currently using Moly E.P. with VRP 5w-30 but don't have any UOA to get an idea if it has any negative effects.
YMMV
What is the evidence you need more viscosity?
Synthetic 5w20>>blend 5w30.
As someone who has owned many, many Fords 4.6L V8's. ( I have owned 7 Crown Vics many high mile used Police cars ) As a simple man I find it best to not over think things Ford Engineers have already done for me. If that oil cap has a big 5w-20 in bold yellow letters printed on the oil fill cap, who am I to not use 5w-20.
Seriously I tried 10W-30 once in winter ( 30F to 40F ) and could "feel" the drag on the cold engine, I went back to 5-20 and never looked back.
As stated previous, just run it and shorten your OCIs -- 4K.
This.
I do not think mixing anything to your oil is a good idea, not even the same oil with a different viscosity. If you can return it, return it if not, shorter OCI should do the trick. Engine oil is like a fine crafted fancy dish in my mind. All the parts needs to be in harmony. All things equal i might have a taste for spicy food, but blindly adding spice to a dish may not work well, perhaps it is a cheesecake that i am poring chili oil to! (Disclaimer: no judgement if anyone loves spicy cheesecake)
That being said, I have seen exceptions to this on transmission oil. Many people including me do indeed mix 2 different products sometimes. I mixed Redline MTL with 75w90ns in i believe 1 to 4 ratio. I am not sure how good or a bad idea this is, it was simply what owners of the same model were doing, and I simply followed them.
