Transcript of a conversation with Mazda regarding "recommended" vs "required" oil viscosity
Does anyone know of any anecdotal evidence where an engine has failed and the vehicle manufacture actually took an oil sample , tested it and denied a warranty siting the wrong viscosity of oil being used?
BMW in the early-mid 2000s around the time of the S54 bearing recall and introduction of 10W-60 for M engines. I am not sure it was denied but they definitely sampled oil on failed engines in a few cases I know of. I imagine if you used a non-approved oil, or an oil that deviated suspiciously at least, they would try to deny your claim instead of replacing $25k engines. When those engines fail early in the lifecycle they send BMW NA field engineers out.
All of these sorts of exercises are pointless for the most part for several reasons.
Not the lest of which is that outside of a few known problem children the chances of you having an engine failure in a new car are very small, the chances its related to oil even smaller...
Another big factor is that people don't know the question to ask as i already pointed out... a manufacturer of dealer can say unequivocally that using 20/50 wont void your warranty because it wont. A denial of coverage does not void the contract.
People see MMWA as some sort of Kryptonite and it isn't, in addition to the fact it isn't kryptonite how are you going to enforce it? Unless you're a bored lawyer looking to do a bunch of pro bono work for yourself it is a losing proposition.
What you need to be asking your self it at what point the burden of proof shifts to you and what the payoff is for the risk.
Well said. As I mentioned and another member posted in a comment - it's all a risk formula. There is a risk - albeit smaller than most would think - that something goes wrong in the engine and the OEM denies coverage on that issue because you used some non-recommended grade. I do have the luxury of working at a dealership so our group takes care of it's employees very well so I have that in my corner as well as almost free labor to do an OCI and a new OEM filter.
But it we weren't all a bunch of nerds asking oil "what about/what if" questions, they could close the forum to new comments and pin maybe 15 topics that could answer almost any question.
If you want a transcript from a real bot (chatgpt), this is what it told me:
While it's generally recommended to follow the manufacturer's specifications for oil viscosity, some variations may be acceptable depending on your driving conditions and climate. The key numbers in oil viscosity, such as 0W-20, 5W-30, or 0W-40, indicate the oil's flow characteristics at different temperatures.
Here's a brief explanation of the numbers:
  • The first number (0W, 5W, etc.) represents the oil's winter viscosity or its flow characteristics at low temperatures.
  • The second number (20, 30, 40, etc.) represents the oil's viscosity at operating temperatures.
In your case, the manufacturer recommends 0W-20 oil for your 5.7 Hemi engine. This means the oil has good flow characteristics in cold weather (important for engine startup) and maintains proper viscosity at normal operating temperatures.
If you use 5W-30 or 0W-40 instead of the recommended 0W-20, there are a few things to consider:
  1. Cold Weather Performance: Using a thicker oil (higher first number, like 5W or 0W-40) may provide better protection in extremely cold climates. However, it might also make engine startup slightly harder.
  2. Hot Weather Performance: Thicker oil generally provides better protection at high temperatures, but using an oil with a higher second number (like 30 or 40) could potentially affect fuel economy.
  3. Fuel Economy: Manufacturers often recommend lower viscosity oils like 0W-20 for improved fuel economy. Using a thicker oil may impact your fuel efficiency slightly.
If you're considering using a different viscosity, it's a good idea to consult your vehicle's owner's manual or contact the manufacturer to ensure that the oil you're considering meets the required specifications for your specific engine. They can provide guidance based on your climate and driving conditions. Keep in mind that deviating significantly from the recommended viscosity could potentially affect your engine's performance and warranty coverage.
The probability of engine failure in warranty period is very small. Even if it does fail, use of different viscosity will not automatically void your warranty, the probability of both events is like 0.1%. Who cares about such a small chance, you probably have higher chance of totaling car in accident. Just stop worrying and enjoy it.
From all this, it seems that the bottom-line "requirements" are the labeling on the oil should be the API "donut" and an SN rating. It seems that most "Boutique" oils like Amsoil SS and others do not have this. Most likely meet or exceed the requirements for such labels, but have not paid the necessary fees to aquire them. I can't visualize a lubrication failure using them, but the requirement is there in the manual. As my Honda dealer's technician indicated, denials are most often due to lack of documented service and sludging. As you can see in my signature, we run Mobil1 5W-30 EP in our CRV which is a real dilluter due to mostly short-tripping, this was at the suggestion of both the service advisor and the servicing technician. I've given up playing "filter roulette " due to the constantly changing ownership/quality changes and countries of manufacture and just use the Honda factory filters, fully realizing that it's a Fram in a blue can, but Honda warranties their engines using it. All service is at the dealership so documentation isn't something to worry about.
I really didn't see any of it as a hard legal requirement frankly.
Yeah, from warranty perspective the manuals are more strict about oils with API seal rather than viscosity.
My Acura manual requires oil that has API seal(always use oil with API seal logo), but when it comes to viscosity it has very vague langue:
1. “use viscosity that is appropriate for your climate”. Hmn, so thats a green light for 5w-30 because it’s appropriate for my climate?
2. Recommended viscosity is 0w-20. The word “recommended” is a key here. For other fluids like ATF and coolant they are using words like “required/specified”. From legal interpretation of “recommended” viscosity, Honda will have a hard time proving that you did something wrong. You could probably even sue them based on the language should they deny warranty because it was other viscosity.
Most mechanics I have worked with - and likely service writers and managers - would say, " Amsoil? that's good stuff. "And that would be the end of it.
Most mechanics or S.M. don't have a clue what ILSAC is, and if prodded and quizzed they may respond " Whoa, Isn't that some sort of "family jewel" problem!?
For Honda manual, they are saying it must be labeled with API seal. But not so much about viscosity.
Apparently the dietys at CAFE require most if not all manufacturers strongly advocate that they use the lowest viscosity oils for the purpose of increasing mpg. I would surmise there's some sort of financial incentive for them to do that. Sometimes it's that, not engine longevity that's the priority, especially in small displacement Turbocharged engines. Yet in other countries and climates, ironically other, higher viscosity is recommended. Seems to be a US prerogative only.
Where does it say must? I read no imperatives such as "shall" and "must" there.
A couple "may" words.
I posted the manual page, its pretty clear to me that they are stating it should have API seal:
“you may also use synthetic oil if its labeled with API certification label”
Pretty sure they want a "API Licensed Oil" but grades are questionable.
Yeah, thats my take from reading it also. With Grades you can potentially argue and say that the manual recommends to use viscosity appropriate for your climate and that 0w20 is recommended and not required. But with API seal they dont say “we recommend API seal”. With that being said, I highly doubt Honda will say this about amsoil SS, but maybe if you put some unknown no API seal oil they will have an issue with warranty…
I don't see where it says "must"?
Right, no must, but it says “as long as its labeled with API seal”. Thats a stronger statement unlike “recommended 0w-20” and “viscosity appropriate for your climate”. From legal perspective they could denny warranty when using non API oil based on that statement (only if they really want to do it and able to show the issue is oil related)
They can probably denny warranty with all the right receipts if they see something is wrong with the oil causing a failure. A lot of possibilities and what ifs….
