I wouldn’t necessarily disagree, was just curious what the most skeptical would consider definitive proof.
the most sceptical wouldn't accept anything they didn't witness themselves.
Nope. Not good enough. Only marketing. Clearly you’re a paid spokesman. Or an AI bot. Or just a figment of our collective imaginations due to hallucinogens planted in the public water supply by agents of VL Inc.I don’t need a test other than my own. 6k miles on my first use in my 2009 Mazda 5 and oil consumption is down about 50%. Mind you it only used a quart in about 6k miles before that. But still… down to half a quart now. I would call that good success already and its only the first OCI.
The Mazda 5 has 193k miles at the moment.
Color doesn’t give any indication of cleaning. David from HPL told us in another thread that it is mainly aminic antioxidants that change color from heat they are exposed to.Right. This first OCI will only be approx 2k miles so if the color darkens considerably, that certainly could support some anecdotal evidence to follow up on.
More than just their tests would prove necessary.No other tests needed. Valvoline has already provided enough proof.
Would anyone know how effective is Valvoline Restore and Protect on Varnish below the valve cover?Well Valvoline did the work for you by testing it in their engine lab. They also did field testing with it. Anecdotal and photo evidence is showing it works as advertised. The only people that may complain about it are those thinking you can run it for 1k miles and expect everything to be 100% back to OE cleanliness levels.
You probably don't need VRP and HPL EC30 together, on the first use.I did the first oil change to me yesterday after I purchased a 2014 Acura TSX (K24 engine) with 25k miles. Since the prior OCIs were around 7k-ish miles but 2-3 years on average I wanted to start fresh and since VRP is the talk of the forum and affordable I decided to run that along with a bottle of HPL EC30 I had lying around.
I do not have the depth of knowledge as some of you so I’m curious how I - or any of you - could be convinced in your own car that 4 OCIs worth did “work”. Since HPL EC30 is part of my initial mix and since I asked Dave on its usage in another car I used it in, I will be doing a quite short initial drain/refill 2000p-ish miles from now per his recommendation and changing the filter; will be cutting open the old filter for inspection. What else, short of doing a full tear down, would be a good test/evidence for its purported effectiveness after 4 normal OCIs?
I have an older Snapper lawn mower the burns an insane amount of oil for every tank of gas. I will try some R&P......Hopefully someone here is willing to use their lawn mower for a test, involving taking the piston out and photographing it. Do it before using VRP, run VRP for a long enough time (~ 120 hours) roughly corresponding to a typical OCI in a car, then photographing the piston. That requires serious dedication, so I doubt any of us will do it.
Have you dropped a comment on PF’s channel yet?Hopefully someone here is willing to use their lawn mower for a test, involving taking the piston out and photographing it. Do it before using VRP, run VRP for a long enough time (~ 120 hours) roughly corresponding to a typical OCI in a car, then photographing the piston. That requires serious dedication, so I doubt any of us will do it.
Done.Have you dropped a comment on PF’s channel yet?![]()
I’m speculating, but I think anywhere the oil comes in contact with should work to remove deposits. I personally have seen much more evidence on this board and elsewhere that show vrp can remove varnish as compared to ec30Would anyone know how effective is Valvoline Restore and Protect on Varnish below the valve cover?
I have a bad case of this varnish identified when the valve cover gasket was replaced.
I have 6 quarts of HPL EC30 in my stash, was thinking about using in 1:5 ratio for each of the next 6 oil changes (OCI = 5,000 miles).
But would Valvoline R&P be more effective against varnish. Probably the answer is it's unknown, but just wanted to check if anyone has had any good varnish removal experiences with Valvoline R&P.
Made to run full oem OCIs. Valvoline also claims it won’t overpower the filter so no early changes neededis this a short change oil or can I run it for normal intervals? Assuming the engine doesn’t dilute it.
