List the:
1) Year/Make/Model/Transmission
2) Miles on Transmission (approx)
3) Service Interval for ATF/MTF and rough description of past transmission service history.
4) Describe method of servicing, i.e. flush, drain/refill, multiple drain/refills (how many)
5) Brand/Model ATF or MTF
6) Filter Change and pan cleaning at each service, yes or no?
7) Additional "accessories" on the transmission (i.e. remote filter, cooler, etc)
For me:
A)
1) 92 Toyota Previa
2) First service was done in Fall 2004 with 44,000 miles on the transmission, yes original transmission. Plan to drain and refill through the drain plug only every 30-40,000 miles at the dealer.
3) Currently 55,000 on the transmission
4) Single drain and refill, removes approx 4 qts.
5) Chevron Dexron III(H)/Mercon from the dealer
6) No
7) None
B)
1) 96 Saturn SL2, 4-spd GM TAAT unit
2) Service interval is approx 30-40,000 miles. First service was done at 35K with Pennzoil Dexron III(G) and new OEM spin-on filter, second was done at 70K with Dexron III(G) but spin-on filter was NOT replaced.
3) 88,000, but will have to rebuild soon due to possible problem with 1st gear.
4) Single drain/refill, removes approx 4 qts out of 7
5) Varies...Any DexronIII(H) or Dexron VI fluid from now on
6) No
7) None
[ February 26, 2006, 02:36 PM: Message edited by: Michael Wan ]
For me:
A)
1) 92 Toyota Previa
6) No
7) None
B)
6) No
7) None
