Originally Posted By: aquariuscsm
Originally Posted By: BuickGN
Just ordered a few gallons myself for the TL and Murano.
Do you plan on converting the GN over to RedLine?
Definately. Part of me says why mess with what works (dino 20w-50), the other part can't help it. This engine is living just fine so far with nearly 30,000 on it, I may pull it and check the bearings and if all looks ok, I'm going to switch to Redline. If it fails shortly that will be the last time I give synthetic a shot.
Believe it or not I have plans to try it on a roadcourse detuned with 19psi boost vs the 29psi it was dyno'd at.
Ya gonna try some Redline 20W50? I`ll be really interested to see how your beast runs on that stuff. Only synth I`ve tried in 20W50 was RP.
One thing is for sure, I'll know in a matter or months when the pressure starts dropping off if it didn't like it. I want to try the YB you suggested too. I would also like to look at the HTHS of the various oils I've tried to see if there's a relationship there. Sooner or later I'm going to have to build a forged 4 bolt bottom end.
