I think the single best thing you can do to keep the catalysts healthy is prevent your engine from becoming an oil burner.
So maybe Valvoline Restore and Protect (see, mods, I typed it all out) is the best choice overall to keep the catalysts healthy?
There's no SAPS level low enough to let the engine shrug off huge oil consumption. Nor is there a SAPS level high enough to worry about if the oil consumption is nil.
SAPS and catalyst health only became a thing when we moved to oils that can't keep engines from becoming oil guzzlers.
Industrial diesels are running CK-4 oils with a full 1% SAPS and SCR systems that, if compromised, could lead to not only replacing $50k worth of catalysts, but hundreds of thousands of dollars or more in fines from the unelected emperors at the EPA and CARB.
If 1% SAPS was a major risk to SCR systems, there's no way these two would coexist.
Which is why SAPS is primarily a DPF/GPF risk, and not a catalyst risk. And the "risk" there is just shorter service intervals where they need to be cleaned and have the ash removed.
All the mid-SAPS Euro oils (C30/504.00) are 1% or less, just like CK-4 is. Heck, even a 502.00 oil is still under 1.5%. But of course, you still won't see SAPS levels that high for any current API spec unless it's 40 grade. That's why Castrol Edge Euro 5w-30 is only API SL (full SAPS 502.00) but the 40 grade (also 502.00) is API SP. SP allows higher SAPS in 40 grade.
There's just no reason to worry about SAPS levels. This is purely the concern of out of touch bureaucrats taking in Powerpoint presentations from activist groups pointing out how OMG the planet is dying because global COs levels are 10ppm higher and we must absolutely protect our precious catalysts at all (socialized) costs!
Run whatever oil you want, there's almost no current spec that allows oil formulations that can do any damage to your catalysts over a decade or more of service unless the oil consumption goes ballistic. So run a good oil regardless of its SAPS levels and you won't have any catalyst issues.
