You guys got me thinking all sorts of oil stuff now!
My 1970 Donzi 18 is powered by an original Holman Moody 351 Windsor 290hp. It uses a factory original bypass instead of a circ pump, that's fed from a Jabsco crank mount water pump. Even though I use a thermostat, (tried three so far), the engine runs very cold, around 120 degrees. (I verified the temps with an infrared...) I don't have an oil temp gauge. Apparently this is very common on this setup, as verified by several fellow owners on the Donzi forum, as well as by Alan Brown, (the general manager of Donzi when my boat was built.)
With this in mind, what oil will protect well at those temps? I've been running either HDEO 15w40's or Kendall 20w50 along with some Valvoline Synpower additive. What do you guys think?
Jim
Jim
