Looks good thanks for the Pic!
I recently had almost half of my bumper ripped off in a hit and run in a parking lot. Since I carry a $1k deductible, it didn't make sense to make a claim, as the damage was just the bumper. I could replace the broken bits with stock for just under $1k, or go with aftermarket for ~$600 and change the look a bit. Since she has been relegated to tow pig and maybe now even "dog truck", I went with aftermarket...plus I got to add some cool (BRIGHT) lights - no, I won't use them on the road. Anyways...what are these pieces of steel that are welded to the frame? Guessing something to do with a snowplow, and I have seen them on other Silverado trucks before, but just looking for an official answer. I might cut them off to clean up the look if they are as useless as I suspect they are...
View attachment 28851View attachment 28850
I wonder if if had some function with the original bumper. Is this a bolt on like these or is it welded?
That must be like 400lbs of rust proofing under there. I'm kidding. I am glad I don't live in the rust belt.
The bracket might be used when the welded frame is shipped from Budd Automotive to GM, it might allow the frames to stack and nest better or give clearance for more critical features.
The ones I linked to are for a 2014 IIRC, its possible they changed it from welded to bolted for the very reason you want to remove them. Just a guess I really have no idea, I have seen them but never questioned their purpose.just like that, but mine are welded
The only part of the picture that has anything to do with transporting the truck is the tilted oblong hole on the left side of the picture.I think they're used to strap down the vehicle for transport. Though I've never seen them welded to the vehicle.
Wdn, my 2017 has a ton of crusty rust underneath. What do you use? I've used Rust Check but it doesn't seem to last the whole year.
My guess as well.I wonder if this bracket could be a safety feature to prevent the vehicle from going over top of a smaller/lower vehicle when involved in a front end collision.
Fun seeing ISU plates on a forum. I'm live just north of the University, in town.
They're there to stop you before you climb something too steep.
They were 1500's.....I don't see them being any good for transport as there is no hole for a hook. Wonder if GMboy knows as he works at the GM Arlington Assembly Plant??
The part serves a sole purpose---to secure the frame as it travels down the frame conveyor in the plant. When the frame gets turned over (to add parts to at a better angle for the operator) it needs those brackets to keep the frame stable as it rides down the line. That is the reason and that's what they are for. We only build 1500 SUV's at Arlington so cannot answer for the 2500 pickup plants but my guess would be their processing of the 2500 frames don't need them or they don't flip them.
