OVERKILL
$100 Site Donor 2021
Could not the same be said of a 5W-20?
(The logic being the base stock has no choice but to be something very good in order to be so thin, perhaps the same with 0W-20 if I now think about it. High % of synthetic even if "conventional" oil no matter the brand or type?)
0w-20 you are closer to the mark, but both can be blended easily with Group III. The 5w-20 winter designation is an easier target with a cheaper base because of the relatively narrow spread, same reason it is cheap to blend a 10w-30.
Also, the Noack limits for GF-5 and the like are not low. There's no equivalent of Porsche A40 for your typical SN GF-5 5w-20 or 0w-20 and they of course have to fall within the Zinc/Phos limits for your traditional SN grades, whereas 40's are exempt, so you get higher levels of AW additives too.
I am presently running a 0W, I chose Castrol. I wonder if I should run a 5W, maybe Mobil 1 when winter hits, not sure the flow on my 0W oil (Castrol Edge) is great. It may be good, but, can I do better?
Looking specifically at the Mobil product portfolio, the 0w-xx grades all have higher concentrations of PAO than the 5w-xx ones. So the 0w-xx are the more expensive oils to blend.
I should add.. cold flow. Perhaps I am overthinking and the 0W (0W-40 Castrol Edge is my present fill) is fine, flows well enough, etc. Or I could choose a better flowing 5W (someone just mentioned Redline, then there is Mobil, Pennzoil/SOPUS which includes QS, a whole slew of oils are 5W.) Many options.. Is it significant for a superior flowing 5W to a 0W which may not flow cold as well, remember oil in a pan is like Jell-O sucked through a straw going up, or is this not exactly worth obsessing over?
Not sure what you are saying? As long as both oils are pumpable, there's really not going to be any difference in flow until you start to approach the limits of the Winter rating, at which point the 0w-xx has a marked advantage.
I am happy we are touching on that just because an oil is 0W, a 5W may be better, almost superior, in cold flow. I feel some do not know this.
That goes against the very premise of the Winter rating system which is predicated on performance in two key areas: The oil's impact on cranking speed (CCS) and the oil's ability to be pumped. A 0w-xx has to meet more stringent standards for both of these metrics even if, due to having a higher 100C visc, it's a a more viscous lube at temperatures where those factors don't come into play. At those temperatures, either oil is going to flow just fine, because lubrication is pressurized and oil pumps are positive displacement. About the only artifact you are going to see is higher oil pressure.
GC 0W-30 seems to get knocked for being another poor cold flowing 0W oil.. Castrol again. Thicker oils as well, I wonder if that impacts on their poorer cold performance. They say 0W.
Mobil 1 on the other hand, let's say 0W-40 for example, I wonder it's cold flow performance, including vs a 5W.. Interesting.
GC 0w-30 passes the same CCS and MRV requirements as any other 0w-xx lube. It will be inherently more viscous than a lighter oil like M1 EP 0w-20 for example, but it will perform as required.
