wtd
True. Wasn't thinking when I asked that.You generally wouldn't heat shrink an insulated butt crimp.
Here is the post I started about what happened and a few pictures.How much damage is there?
Have you priced out a complete power train harness?
Why not? They make ones that are designed to shrink and seal.You generally wouldn't heat shrink an insulated butt crimp.
3U2Z-14A088-AB, 3U2Z-14A088-BA, 3U2Z-14A088-CA are the numbers for the kits based on gauge size.Do they recommend insulated ones or un-insulated ones?
Excellent point, I usually try and strain relieve crimped splices when I can. I like to leave a little slack and secure the wire so it isn't flexing or pulling at the crimp at all.Generic butt crimps are terrible by them selves. Any movement at all and the wire will break right at the crimp. The ones with heat shrink are slightly better. I have soldered many and never had a problem. People say that the wire will break near the soldier. Mine never did.
I prefer the ones with shrink tube, but if I don't have them and depending on the application (vibration, flex, moisture), I will use a standard non-shrink insulated one and put a longer piece of heat shrink tube over the connector to seal and support the wires outside of the connector. I will especially do this if the wires have to bend coming out of the connector; to Chris' point, you don't want the stress at the crimp.Why not? They make ones that are designed to shrink and seal.
Thanks for these links. Very informative.Crimp tools range so wildly in quality and function, and then there is the skill of the user, or lack there of.
Soldering is an acquired skill and can also be done poorly yet look acceptable.
Solder is not a great conductor, so tinning two copper wires then touching them and soldering them together, can have significantly mroe resistance than wires twisted together then soldered, or when a high quality butt crimp is used, done properly in a quality crimper.
I'm not big on electrical tape, but sometimes it is necessary. Adhesive lined heatshrink is my goal.
if time is not a factor when tape is the option, use liquid E tape, a thin coat and then the E tape sticks insanely well to it once dry. Small Zip ties over the E tape can keep it from unravelling, but one should also cut it, not tear it , and not stretch the final wrap, to prevent it unravelling.
Huge difference in the quality of E tape available as well.
Working around old bad quality E tape is a sticky mess of a nightmare.
The Marine guys can take it to a different level.
Marine Wire Termination - Marine How To
Marine Wire Termination - Tools of the Trade MHT Recommended Tools: The products below are our top picks for crimp tools. RecommendationsI include; PRO GRADE, MARINE GRADE, & PENNY SAVER GRADE. Every tool recommended BELOW, we have tested here.marinehowto.com
Solder and Poor Trouble Shooting = $$$$ - Marine How To
The Wire That Caused Years Worth Of Expenses So I get called to winterize a new customers boat and it has already been hauled to their house and needs to be winterized on the hard. Notmarinehowto.com
Making Your Own Battery Cables - Marine How To
Pick Your Crimp Tool FTZ 94284 & Ancor Hammer Crimper TEMCO TH0005 & FTZ Bench Mount BUY FTZ 94284 CRIMP TOOL - BAY MARINEmarinehowto.com
How is that different from a butt connector? lolI've never been a fan of butt connectors so what I usually do is use male/female spade/bullet connectors then cover the splice with heat shrink. I've had pretty good success using this method for the past 20 or so years.
I'm not good at soldering so that method is probably not going to be used unless I decide to use the solder filled butt connectors that I have.Either method is fine. It depends on how comfortable you are with soldering.
Also notice one important thing. The wires themselves, regardless of method, need to be clean and shiny, no corrosion present. They also need to be in close contact with each other and preferably mechanically joined to prevent movement, which will result in that "cold solder" joint if not.
The amount of room that you have to work with, adjacent items that cannot take the heat of a heat gun etc. will also make the determination.
And no, heat will not make the nearby insulation brittle. A heat gun would be more prone to doing that than the concentrated heat of a soldering iron.
And yes, definitely use shrink tubing with a filler to seal out the elements. When repairing one wire, you are actually doing TWO repairs. One for the conductor, and another for the insulation.
I want to mention that I only did this method as practice to try it out. I didn't actually repair the car yet using this method.Has anyone ever used the first method described in this article? I tried it yesterday and covered it with heat shrink instead of tape and it seems to be very strong. Leaves a little bit of a bump in the middle but not bad.
I was wondering if this would be a better solution given how small the wires are.
Fundamentals of Automotive Electrical Connections and Connectors
In my opinion, this is the single most important chapter of this book. Nothing is more telling of your wiring skill than the quality and integrity of your connections. In addition, your connectivity makes or breaks the reliability of the circuit you’re adding, adding to, or repairing. If there...www.musclecardiy.com
