Alot more to it than that. When oil is ran too long and breaks down, so does the engine protection. When the AW/AF additives go away, so does some of the wear protection. Then there's the neglect factor where some people never check the oil level and it gets to the point of inadequate lubrication situations. That wears and smokes engines pretty fast.So often the car that is dying early is written off because of a lack of proper oil changes. What happens? There is evidence that there is LESS wear with extened oil changes.
Certainly the oil oxidatively thickens increasing the MOFT. So wear should go down. The longer you run, the thicker the oil, the thicker the MOFT, ultimate wear control according to some. Wear should be zero.
What is wearing out and why?
Ali
