What grease for brake caliper slide pins?
Originally Posted By: Ethan1
That's the point
There's already at least 12 years' worth of discussion about this...
Yeah, but we're bored....Lets talk about it one...more...time!
^ I'm with you. ONE MORE TIME!
The guy who posted the Anti-Seize should be pilloried. That stuff turns into dry clay and shouldn't be used on brake pins. Anti-Seize is for bolts only.
Originally Posted By: dlundblad
Nobody mentioned Permatex synthetic caliper pin grease.
$12 on Amazon for Prime Members.
Don't use that - it will cause your calipers to lock up.
Use Sil-Glyde, the Motorcraft/3M silicone greases or Dow 111. You can also use Toyota's red rubber grease as well.
+1
I'm trying to figure out what I CAN use that junk on...
