I’ve used silglyde, 3M silicone paste, and now Raybestos silicone paste. Never an issue with slide pins with any of these
Not if he was using silicone before that.If it's a Toyota, probably want to use their red grease.
I also had purple failure. Turned gritty seized up.Coming up on 2 yrs ago this spring.
I would skip Toyota grease. The pins get stuck for some reason despite grease being there and no corrosion.If it's a Toyota, probably want to use their red grease.
That's because it's a grease made for internal parts on brakes such as super piston seal. It's the RX formulation.I would skip Toyota grease. The pins get stuck for some reason despite grease being there and no corrosion.
I had a hard time believing his when I read people claiming to his, however I decided to check the pins few months ago on my Toyota and all of the pins, except one, were stuck. And this is a 100% Texas car, never seen salt or snow with only roughly 25k miles when I checked the pins.
Internal brake parts are lubicated by the brake fluid? why would you want to use a grease?That's because it's a grease made for internal parts on brakes such as super piston seal. It's the RX formulation.
You want RN formulation that has solids in it.
Or just get silicone paste in plain flavor or something with solids like CRC silaramaic.
You use it on square piston seal in the caliper. It plays well with brake fluid.Internal brake parts are lubicated by the brake fluid? why would you want to use a grease?
Also I avoid silicone with solids not reliable esp. in salt land.
Plain silicone such as 3m, mission etc, or sil glyde.. only IMO. on pins..
now on pad ears and backing I use pastelub. 40% solids.
FYI, I reported here that Pastelub changed formula during Covid. I talked to Gary at GWRAuto in Florida and he now has the original formula back in stock and I ordered/received 6 tubs.Plain silicone such as 3m, mission etc, or sil glyde.. only IMO. on pins..
