What do you conclude about a "loud" oil?
Mobil 1 0w40 should according to you up the noise?
The thing has a lot of PAO and has a generous moly additive pack if anything it'll smooth things out inside the engine.
That's not what I said. I am going to add it in, if it needs, to show the "noise" should stay the same.
I thought Mobil 1 was frequently called a LOUD oil.
Just topping off with new oil isn't going to be much volume of new oil, so doubt that's going to tell you anything.
Just adding a small amount for top up doesn't prove or disprove anything, and my experience with Mobil 1 0w40 has been that it's as quiet as anything else I've tried. Not sure if it's quieter but It's definitely not louder.
Mobil 1 15W50 always ran smooth as silk in my 300ZX. It was my go-to oil in that car.
That oil was noisy in my 350 Olds, but I eventually figured out anything 40 weight or heavier seemed to be noisy and 30 weights were quieter regardless of brand. To confuse things more I used GC 0w30 several oil changes back in the day and it was almost as "noisy" as the 40 weights (it's almost a 40 weight) but recently I switched to Mobil 1 0w40 which is almost as thin as a 30 weight and it's dead silent.
