diyjake
What is so special about Mobil 1 ESP? I don't remember ever seeing in the stores but then again I was never looking for it. [/quote]
Mobil 1 ESP is made for European diesels and gas engines using ULSG. Mobil 1 ESP Formula 5W30 (recently discontinued) was probably best oil in that category, but that is NOT your ordinary 5W30 ILSAC GF-5 oil. HTHS was 3.58cp, and KV100 almost on par with W40 engines. It is absolute overkill for any Toyota here in the US. In Europe, that oil is though recommended for these 2GR engines, but European roads have different driving requirements.
In Sienna I use Mobil 1 Extended Performance 5w30. Reason is that twice a week I ski, and climb I70 where I keep engine using manual mode above 4000rpms for like 45min to an hour. Call me old fashion, but I am not believer in these W20 oils. But, do not overkill it. I think jump to W30, either 0W or 5W will do.
I went with Mobil 1 Extended Performance 5w30 as it meets ACEA A5/B5, has bit more additives. But, seriously, in this engine you can use ANY synthetic oil 0/5W30 and be fine. It is simple, proven engine.
Also, I used FRAM Ultra first two oil changes. I did first oil change 3K (as I do not know who owned car before me, I got it with 42k on ODO). Than 5K using mix of 0W20 and leftovers of 0W40 (2 qt) I had from my VW CC from like 4yrs ago. And now using Mobil 1 Extended Performance 5w30 and OEM filter. Reason for OEM filter is that dealership had sale, 3 filters for $12. It fits better in housing than FRAM. I will change this every 8k. No need for every 5K if you use oil such as EP as this is port injection engine.
Mobil 1 will be bit louder. I had that issue in my Passat 1.8T, in VW CC 2.0T and once I used in Tiguan 0W40. Interestingly, Mobil 1 ESP Formula that I used in my X5 diesel that I traded in for Sienna did not exhibit any more noise than other oils I used in that diesel.
Do not overthink. I got Sienna to keep it 15 years until kids are out. Though, pay attention on some assembly things, as IMO car is below average in built quality.[/quote]
Thank you for all of this information! I am currently running Mobil 1 Extended Performance 0w20 (I choose 0W-20 over 5W-20) because 0W has more PAO / better base.
