Everyone also harps on Hyundai and Kia around here.....It's amazing to me Jeep has any customers left.
Chrysler seems just as bad, yet.....crickets.
My Jeep is 6 years old with several hundred miles off the pavement - zero issues - my Charger was 7 years old - zero issues - back to crickets …Everyone also harps on Hyundai and Kia around here.....
This is 100% true. However the use of higher viscosity will markedly improve component life, likely to reasonable levels. It just won't fix the problem of plastic camshafts and roller followers made from Dark Chocolate. Mobil 1 Extended Performance 5w30 is a fantastic oil, with an AN base. That AN means the relatively modest additive pack is more effective than other oils with the same add pack levels. You will find a wide array of opinions here on Mobil 1 Extended Performance 5w30 including those who claim other oils are superior. In practice that's just not the case. The EP is a top tier oil and performs like one.I think it's a metallurgy issue that isn't directly correlated to oil type.
Melling kits Ok ?Pentastar rocker arm and subsequent cam/lobe damage has nothing to do with oil. What you do is budget rocker arm replacement every 100k miles and fix as soon as you hear noise so you don’t damage the cam. This is a 15 year old problem, every oil has been tried. Rule of thumb: Pentastar V6 valvertain typically fail around 100k miles and Hemi V8 valvetrain typically fail around 200k miles. If you want/own/love these engines plan accordingly.
Oil brand doesn’t matter just as long as you’re keeping a steady oil change interval. Maybe cutback on the oil change interval keep it around 5k 0W or 5W20 will do it.Hi guys,
Long time viewer few time poster, I live in suburbs outside Chicago. Daily driven 2019 Jeep grand Cherokee Laredo 88k on the clock. Mainly city/suburb occasional highway driving. I Bought it used with 40k mi in 2022.
Since owning the vehicle I consistently used Mobil 1 Extended Performance 0w20 and Mopar mo-349 oil filters for 5-8k OCI.
It fell to the dreaded “pentastar tick” recently had both intake cams, rockers, lifters, pcv valve, Vvl solenoids and lifters replaced in December. Total cost $2.5k by ordering mopar parts online rather than the stealership charging $12k for a new engine.
I’m currently running Mobil 1 Extended Performance 5w30 and Mopar oil filter. Would 0w40 benefit in any way? Or, should I stick with 5w30 going forward?
Good for you.....heres a stickerMy Jeep is 6 years old with several hundred miles off the pavement - zero issues - my Charger was 7 years old - zero issues - back to crickets …
Can you even find dino anymore?Oil brand doesn’t matter just as long as you’re keeping a steady oil change interval. Maybe cutback on the oil change interval keep it around 5k 0W or 5W20 will do it.
Grow upGood for you.....heres a sticker.
Good boy...Grow up
On ignore
Why bother with the cost of synthetics these days. Super tech synthetic and advanced synthetic best bang for the buck or a havoline bay boxCan you even find dino anymore?
Semi syn is the lowest I can find in my area...at it's only 10% of shelf stock. Rest is syn.
Yeah this old trope again. That sure sounds good, but we have a forum full of people with oil burning and other issues using high quality OTS synthetics. For many, it does matter. Glad it's worked out for you, but you can't extrapolate that experience to everyone's cars.Oil brand doesn’t matter just as long as you’re keeping a steady oil change interval
Listen I don’t lie but I may tell stories no one’s engines is ever going to tell what brand oil goes in and it sure won’t quit with proper maintenance and oil changesYeah this old trope again. That sure sounds good, but we have a forum full of people with oil burning and other issues using high quality OTS synthetics. For many, it does matter. Glad it's worked out for you, but you can't extrapolate that experience to everyone's cars.
I’m not hearing crickets. There is plenty of criticism of the PUG on this forum.Everyone also harps on Hyundai and Kia around here.....
Let’s keep the talk adult no need for name calling and far from uninformed. Anyone on here can talk their love and affection for any oil brand their heart desires. I can’t and won’t accept that a particular brand makes any difference in engine cleanliness and longevity relating to modern synthetic and synthetic blend oils that meet manufacturer requirements and specifications. Not following routine maintenance and oil change practices will fail a vehicle far sooner than reputable oil brandsYou are either ignorantly uninformed or a troll.
Yes the balls in their court. I walk away with no insult to my intelligence.Please read through the countless threads on here of people running OTS oils and still getting loaded oil control rings and oil sludge buildup.
I stand by my statement, you are trolling with the intent to be confrontational.
The mods can state otherwise if needed.
Bath toys on the dash and those dumb angry grilles should be illegal!
