What Are Your Most Favorite Maintenance Tools?
Pushbroom and dustpan. ;)
I use Vise Grips mostly to "enhance" other tools. The last time I used them was to clamp onto a small breaker bar to assist me on a repair on my friend's Odyssey to give me leverage in a very tight space. Worked like a charm!
Yep, MacGyver Grips - or light duty plumbing like 1/2” or smaller pipe … Don’t belong on good fasteners …
boat 1 - 10
Boat 2 - 8
Truck 1-8
Truck 2-6
Motorhome -6
Moho genny-3
RZR-2
Raptor 700-1
Kawi 450-1
riding mower -2
push mower-1
brush cutter -1
chainsaw -1
String trimmer-1
2 honda 2K-2
Yamaha 3K-1
Yardmax-1
Whole house genset 2
backpack blower- 1
power washer-1
Was doing a cylinder/piston and sump count the other day. 59 and 19.
The most common tool between all this is the mityvac.
Autel Maxi-Sys and WiTECH.
Can't work on anything anymore without them to troubleshoot, reset, reprogram, etc...
Don't laugh...
Refilling the cooling system in the Lexus is a PITA. The fill hole is a 20mm diameter plug at the throttle body that's only ~12mm deep and has a tiny hole in the casting that the coolant is to pass through. I don't like splashing fluids all over the place, so I spend what seems like hours dribbling coolant thru this hole and waiting for the coolant to drain into the engine.
I put together this to make the situation a little more bearable. At least the funnel acts as a larger reservoir than the thimble-sized area under the fill plug. If I could plug in a gallon of pre-mix I would.
Fill funnel and flush hose adapter.
Could not set bearing preload without this tool to set the initial torque:
Sunex 10202 4 Wheel Drive Spindle Nut Wrench
I've got a host of 'em....44, 60, 10.25, 14b and something else. Then the whole set of huge sheetmetal hex/rounded hex including the elusive 54mm for Toy IFS
And yet I'm sure I'm lacking the next one I'll need....
Computer with a web browser. That means access to factory service data, Alldata, YouTube videos, forums like this... all sorts of places where other people have already figured out the hard bits. Having a dedicated-to-purpose computer in the garage/workshop, with a mouse and keyboard that I don't mind getting grimy, is a big plus.
If you have Fords in your life, Astro's 18.5mm/19.5mm flip impact socket is a must for those swollen lug nuts...
Vacuum extractor. I've used it on so many random fluids I can't remember most of them anymore. Every person I've used it in front of runs right out and buys one.
