2015 Pilot had its first big problem. Wife calls me frantically yesterday, saying it's stuck in her aunt's driveway, and it won't go into gear. She turned it off and tried restarting, but it wouldn't start. Load up my tools, and when I get there, she tells me the battery light was glaring at her, but she kept driving, even as other warning lights like CEL, VTM-4, and ABS lit up. Ugh. Quick check of the battery voltage, and it's only 11.9 volts. Uh oh. Got it jump started, but the battery voltage is drooping. Great, alternator is kaput. Called AAA to tow it back to our house, and start reading up. Rebuilt alternators are not cheap. The YouTubes looked like it's not too bad to change an alternator. Got the battery recharged, and today the alternator seems to working fine. Already had the replacement alternator, so I'm thinking just replace it, since it clearly wasn't working yesterday. Get it out, and it's covered with oil. Sure enough, the VTEC solenoid on the front is weeping oil. So, another trip to Autozone to get a gasket kit for that, and it's back in business.
Who’s fancy Subaru do I spy?With snow on the way and knowing PennDot loves to throw the rock salt down, I installed some PPF on the truck!
Temporary solution for a design flaw. I lost track of time and never got to properly PPF that area, so this was my only solution.
I did fully Wool Wax the frame and such underneath a couple weeks ago. Truck still smells a little funny...
Was it leaking? Oil or water?I installed a Dorman oil cooler on my 2020 Wrangler 3.6L today. There is no easy way to drain the coolant in the JLU, so I pulled the lower hose and caught 99% of the coolant. It all went back through the overflow tank for the refill.
I never want to do that job again. It wasn’t hard on my 2014 Town and Country, but Jeep has too much stuff in the way of everything. I need to get some electrical connector pliers to help make jobs like this easier as well.
Oil.Was it leaking? Oil or water?
The updated valve from Honda is the only fix that actually lasts. I would do the "upgrade" before you lose the replacement alternator:2015 Pilot had its first big problem. Wife calls me frantically yesterday, saying it's stuck in her aunt's driveway, and it won't go into gear. She turned it off and tried restarting, but it wouldn't start. Load up my tools, and when I get there, she tells me the battery light was glaring at her, but she kept driving, even as other warning lights like CEL, VTM-4, and ABS lit up. Ugh. Quick check of the battery voltage, and it's only 11.9 volts. Uh oh. Got it jump started, but the battery voltage is drooping. Great, alternator is kaput. Called AAA to tow it back to our house, and start reading up. Rebuilt alternators are not cheap. The YouTubes looked like it's not too bad to change an alternator. Got the battery recharged, and today the alternator seems to working fine. Already had the replacement alternator, so I'm thinking just replace it, since it clearly wasn't working yesterday. Get it out, and it's covered with oil. Sure enough, the VTEC solenoid on the front is weeping oil. So, another trip to Autozone to get a gasket kit for that, and it's back in business.
Good to know there's an updated one. Thank you for the link.The updated valve from Honda is the only fix that actually lasts. I would do the "upgrade" before you lose the replacement alternator:
https://static.nhtsa.gov/odi/tsbs/2020/MC-10172366-0001.pdf
