Follow my exploits on my YT channel:So cool, I'm following you now(not really but you brought this on yourself)
https://youtube.com/@karstgeo7290?si=4r5_EvZ_EFcCVUtD
@clinebarger - would you think this is a case where maybe the TC started to slip, causing the heat and fluid degradation, or is this where the driver caused the wear and tear?
These newer transmissionmissions seem to be so good at staying in lockup that they don’t create as much heat internally as they used to?
Truck is awfully clean and the wheels are fancy - does the vehicle tow a lot?
I feel you on chasing parts!It tows a bass boat.
*All the material in the pan is the converter clutch lining, I haven't vacuum tested the valve body yet....But I bet I'll find some of the Pulse Damper Pistons worn out which can cause poor TCC control & burn up.
*The Thermal Bypass has a broken spring cup.....This will cause the unit to overheat from the bypass not opening. Strange thing is not all thermal bypasses used a plastic spring cup but a steel one?? 2014 & up 6L80's can also suffer from this.
I tap the bypass body with a 1/4" NPT tap & install a plug so it will have full time cooler flow.
Got the unit tore down, Inspected, Case washed.....And gathered parts which is the more challenging aspect for me because the time it wastes.
3 different GM dealers, WIT transmission parts, Converter shop & Summit Racing to get everything, Everyone is in "Holiday Mode" whether its on the road or behind the parts counter![]()
I fired up my Simplicty blower and soaked the shoot with fluid film last weekend. I hoped that would keep the snow away.Mounted the snow blower on my LT150 today because apparently we are getting snowmageden on Saturday here in eastern Iowa.
My theory is if I mount the blower it won't snow. This time I'm not very certain.I fired up my Simplicty blower and soaked the shoot with fluid film last weekend. I hoped that would keep the snow away.
@clinebarger Don't those have a transmission temp gauge in the instrument cluster?
I've greased strut mounts in the same manner. Gotta be better than nothingThe other day I did a white trash repair on my 2002 Sunfire, Shtty Blue. Pulled the alternator off and added some more fresh grease to the front bearing. I could not properly access the rear bearing (need a sizeable soldering iron to desolder a few points) so I used a small drill bit to put a hole in the seal. Used a needle to inject some grease and then sealant to patch it. Will it hold? Who knows but im not throwing more money at this beater. Hell yeah brother!!!
Today I have to bring the Trailblazer to town and get a tire patched. Im pretty amazed we got a year on the new tires before picking up a nail.
Probably way, way more common in parts of the world than one would guess.The other day I did a white trash repair on my 2002 Sunfire, Shtty Blue. Pulled the alternator off and added some more fresh grease to the front bearing. I could not properly access the rear bearing (need a sizeable soldering iron to desolder a few points) so I used a small drill bit to put a hole in the seal. Used a needle to inject some grease and then sealant to patch it. Will it hold? Who knows but im not throwing more money at this beater. Hell yeah brother!!!
