What are you working on today?
Biggest issue I've had material wise is drilling 304 stainless. It eats up drill bit ends and does everything it can to harden as you drill. The procedure I do on it is technically coring, but our coring bit is only like 3-4" long, and we need to come in about 8-10". I've been told a coring bit for that length would have to be custom ordered to the tune of about $1400 for 1 bit....so we drill.
I don't mind 304 although I definitely strive for 303 if welding isn't required.
I hate 316. Drills poorly, terrible hole finish, the chips suck and trashes standard drill bits.
For the first time in probably a decade, this Avalon will have a matching set of tires
You'd think she could've sprung for the matching 5th for the spare?
No, so it'll remain the 2010 Factory Bridgestone 🙄
I miss when Toyota gave you a matching 5th Alloy 😔
Mismatched and balding Forceum/Linglongs were ditched for Kumho LX Platinum KU27, a good deal at $85 a corner
TPMS light has been on since a shop screwed it up ~8 years back, so 5 OE type Schrader's went in
It was time for all 5
I like the idea of TPMS in the spare, it forces you to air it up if you want the light out 👍
It had a mishmash of factory Pacific, Schrader EZ clone, Autel MX, and one was just a rubber stem
Clean slate with the fresh rubber
Most pleasant lack of dash emojis 🤌
They ride more than fairly for the $85 a corner price
Who knows how the wet grip will be 👀
2008 FJ Cruiser: finished rear wheel seals. Both sides were leaking. I actually remembered to order the axle housing o-ring (90301-83002) this time and replaced those, too. And I replaced the brake pads just because they were exposed to so much gear oil.
Also replaced the spark plugs. Found the factory nickel Densos in there with 201k miles. The gap had gone from factory spec of ~.043" to .065" but it still ran great before.
View attachment 292000Most pleasant lack of dash emojis 🤌
I've been very happy with the two sets of KU27's I've purchased. I've got them on my '95 Seville right now, and they suit a luxury car quite well. Should be a great match for that Avalon.
Progress on the Hyundai Nu 2.0L.....
I was just browsing Copart and came across a really nice looking 2013 Soul! that's just about loaded... they're asking $975 B.I.N. and it's listed with "mechanical" as the only damage. The pic of the dash shows it running without a CEL or oil pressure light, but it almost has to be at the auction due to a bad engine.
I'd be more than happy to throw a good used engine in it in my shop, judging by your photos it should be a pretty cut and dry job. You've got me thinking...
A new short block & head are fairly reasonable from the dealer. The engine/trans basically falls out of the car if you have a lift.
Bought a wholesale clearout item from RockAuto. Naturally it didn't fit. How do you get something like this wrong? (SKP part 615212) ..actually some Amazon reviews cite the same trouble (from different made up brand names).
Use GM or Mahle, Fel Pro will fit for initial install....But will swell & cannot be reused.
Minor battle with the front bearing race on an NV4500 countershaft.
I finally preloaded with my small Posilock -- the teeth BARELY had a lip to grab -- and then heated with the blue wrench, trying not to directly heat the jaws which I assume are hardened.
It finally went beautifully but wasn't easy. Wonder if @clinebarger has tricks for these?
More work on the go kart.
The front suspension is reassembled and repainted, 4x new 7 inch grade 8 bolts, spindles reinforced 1/4 inch welded gussets.
Grinded some chaff off the floorboard and repainted it.
The rear axle ended up being bent, so I have a new 1 inch axle, spindles, gears, brake disc tires and rims coming from gopowersports. I tried cutting it and rebending it, but the axle still wobbled from an even deeper point, so I gave up. The kit was pricey but I think it will be worth it, i'm still well under what a new or used good condition Yerf Dog Spiderbox costs.
The rear engine support was next on the list. Originally it was made for a GY6, but I'm changing it to a Predator 212. I took some scrap riser parts off a shipping sled which happened to be the perfect width.
Had a ball throwing sparks with the chop saw.
Welded the risers both on to the main engine chassis, and also extended the entire support with thick L channel from a piece of farm equipment I chopped up. I have an engine plate already and will drill holes and bolt it on in case I want to reuse it. A solicitor who was next door watching offered me a business card to do welding side jobs, that might be fun.
Worked on the Yerf Dog go kart, installed the front suspension, wheels, steering rack, rear swing arm, test fitted the rear axle, sprockets and rear wheels. I need to meditate if I'm happy with the rear axle width or not (40 inches). A bit more work to do from here but the main chunks are coming together.
On the Kohler LH775 engine that dropped a valve guide, I successfully drilled and put a set screw to hold both the intake and exhaust valve guides with loctite 640. Ordered a new headgasket, valve stem seals, exhaust gasket, pushrods, lifters. If this works i'll have saved $300-500 vs a new cylinder head. Will know in the next few months.
A 2010 Avalon has a full size spare, with TPMS in it? While my 2014 ES350 has a donut without TPMS in it? 🤣 🤷‍♂️
I love those Kumhos though. Have a set on my Sonata and put a pair on the front of the Genesis. Smooth as glass, nice and quite, better handling than the Yokohamas it had before even when they were new.
My ES350 will get a set probably this winter.
It finally went beautifully but wasn't easy. Wonder if @clinebarger has tricks for these?View attachment 292499
You got it off...All that matters.
I would've weld three pieces of bar stock into a tripod then a 5/8" nut & use a slide hammer, That hard bearing race material spooks me as I've had to remove pieces of it from under my skin more than once. Couple years ago had to go to a Care Now & have a piece cut out, That $800 bill wasn't worth the time saving Cowboy s**t!!
