What are you working on today?
You got it off...All that matters.
I would've weld three pieces of bar stock into a tripod then a 5/8" nut & use a slide hammer, That hard bearing race material spooks me as I've had to remove pieces of it from under my skin more than once. Couple years ago had to go to a Care Now & have a piece cut out, That $800 bill wasn't worth the time saving Cowboy s**t!!
Agreed I had a piece of a chisel shrapnel cut me in school. It was just a really weird cut/injury that took way too long to heal.
I dunno if you followed the controversy with Myth Busters years ago when they claimed to have busted the myth that it doesn't matter if you use a hardened hammer with a hardened chisel. LOTS of people told them they were wrong (I agree) and I think they rescinded their findings.
Ball peins or similar only with chisels! Definitely not framing hammers.
Added one of the few missing options to my Seville: compass! Found an OE on the 'Bay for $29 👍
Diag'd a no-start on a Ford 300 irrigation pump. No spark, no power to the coil. I found the relay in the aftermarket ignition switch had failed, so it wasn't sending power to the coil. It also won't let you shut it off once I got it running by jumpering.
Anyway I found the identical Murphy 117 on ebay for ~$60 so I've got that coming.
Anyway I found the identical Murphy 117 on ebay for ~$60 so I've got that coming.View attachment 292702View attachment 292703
How many of these are still out in service? That engines got some years on it!
Well, I don't have a fancy parts washer so I had to engage the white trash parts washer for this NV4500 case: an old tire/wheel, a piece of scrap futon frame, garden hose and cans of degreaser.
On the bright side I fixed the crappy hose connector with an Oetiker-esque clamp. It was previously spraying back at me and now it doesn't leak a drop!
Try not to be jealous that you don't have old futon frames strewn about your 35 acres ;)
Worked on a 1999 Chevy Cavalier that we bought yesterday for my fiancé's son to replace his 2008 Ford Focus with a bad transmission. Car only has 117,603 miles on it and in pretty good shape. Has some rust on the passenger side next to the rear wheel and a little bit under the car near the back. It's a base model car with an automatic transmission, rollup windows, and pretty much nothing power. AC is very cold and it runs pretty good. Previous owner just put new AC-Delco plugs in it, new wires, a new battery, and did an oil change.
The rear driver's side wheel would lock up in the gravel driveway of the previous owner's home, so I figured the drum brake was not adjusted right. Today I pulled both rear wheels off of it and adjusted that side. Both set of brake shoes had plenty of pad left and had been replaced at some point.
Today I also replaced the fuel filter, gas cap, and coolant overflow reservoir cap which was broken. I'm going to change the transmission fluid and filter and replace both O2 sensors. The after-cat sensor took a long time to warm up and stayed near 0 for quite a while and the pre-cat one seemed to work okay but would occasionally drop near 0 during the test drive. No CEL or codes stored, and all monitors had run so no one had cleared any codes recently. Hopefully he doesn't destroy this car like he had done with the Focus but he probably will.
@wtd when I did the transmission fluid on my 2002 Sunfire, I just unscrewed the top transmission cooler line, right in front of the battery. Pull the battery or headlight to gain plenty of room and I just used the engine to pump it out.
@D60 I appreciate the trials and tribulations of white trash world. I'm tossing our old futon out in the near future. I may just keep the frame for some white trash projects in the works.
