Now it's too pretty to use.One more coat of paint this morning. Probably will be the finish coat.
Nah. I’m going to use it and It’s going to get beat up good. The river I use it on is full of rocks as well as a section of class 3 rapids. It will be nice for a little while. At least everywhere except the bottom.Now it's too pretty to use.
My ‘18 f150 has it. There’s a little buffering to it but it’s not a fake gauge.Factory on all 2500 & up GMT800's....1500 Escalades & Denali's got it as well. Ford started in '03 I believe on all Super Duties?
They seem to know when you are and stay away. IME, they only were interested me when I stopped looking and got the rest of my things good and going and in order. And then it was like, “who’s got time for that?”Looking for a girlfriend![]()
Dang! That's why my Dad told me to never buy used sports cars.2013 Ford Mustang GT, 5.0L/MT-82.....Auction Rat. Compliant of no forward movement & limited movement in reverse.
Pulled the differential cover, Fresh gear oil with a ton of metal in it.....The left carrier bearing had failed & was driven to the point the ring & pinion no longer meshed. In reverse the carrier would shift back to the right.
Didn't grab any pics before removing the carrier as I was hurrying to order the parts needed.....Needs.....
Carrier, Ring & Pinion, All bearing, The left carrier side shims got pretty beat up so I got a set of Super Shims.
Carrier, R&P, & Wheel Bearing are Ford Performance Parts which are same as OE for this application.
Motive Gear master kit that has Koyo Bearings which is also OE. AC Delco posi/LS additive because it's a little cheaper than Motorcraft.
All in stock at the Summit Racing near me for $750.
I completely respect that some people find lawn maintenance calming. I find it annoying and always feels like a waste of my time. Fortunately there is no lawn at my placeView attachment 226039
Replaced the sad and tired wheels on our little 20" MTD push mower. I found these wheels on Amazon while browsing for replacements and loved the idea of having actual bearings supporting the load vs. relying on the plastic wheel hub. It pushes effortlessly now, huge improvement. Link in case anyone needs a set:
7" mower wheels with bearings (other sizes available!)
While I was at it I decided to check the engine speed as it always seemed a little slow. Sure enough, she was only running at 2800 RPM. A little tweak to the governor spring tang and she was purring along at 3300. I have to say, this little thing really cuts nice for what it is.
