2015 Camaro, 3.6L/6L50E, DTC's......
P0451, Fuel Tank Pressure Sensor Performance.
P0446, EVAP Vent Solenoid Performance.
FTP Sensor voltage stuck high at 4.69vdc & reading 15 inches of vacuum, Key on/Engine off after sitting all night (No way there's 15" of vacuum)
I'd usually like to access the FTP Sensor for further diagnoses but that impossible on this vehicle, The sensor is on the top of the tank & the tank overhangs the rear subframe.
Calls for 4.6 hours to remove the tank.
Looked for tips/tricks/shortcuts on the Web/Youtube.......Every video was of cutting a hole in the floor
Service information called for lowering the front of the rear subframe, Then remove the lines at the EVAP Canister....Yeah, Sure....No way my hands/arms fit up there to undo the EVAP lines.
I removed the rear subframe completely & was able to lower the tank just a little to swap the FTP Sensor. Monitored the voltage/pressure, 1.6vdc & Zero pressure.
Hooked my smoke machine at the Purge Solenoid line, With the Vent Solenoid commanded closed....Waited for the flow meter to drop to Zero, Which it did. The FTP Sensor also tracked pressure from the smoke machine @ 8 PSI max.
Commanded the Vent Solenoid off/open & the pressure dropped to Zero.
Only then did I reinstall the rear subframe.
This job really wasn't that bad, Glad I didn't just blindly follow service information!!
