It was 60° briefly today, so a 2017 Optima (92k) pulled up for emergency maintenance
It's the epitome of neglect/abuse, due to a stretched hood cable, it was driven for two weeks with the oil pressure light on
I can think of 5 distinct occasions in the past 6 months that I've had to add 4-5qts of oil to get to the full mark
So a heavy burning 2.4 Theta II, what else is new
- OCI (Total 5w40/OE Filter)
- Oil flush (Motor Medic)
- Spark plugs (NGK Iridium IX)
- Air filter (Wix Pro-Tec)
- Polish and grease battery terminals with Noalox
- R&R throttle body for cleaning
- PCV valve (Beck/Arnley)
- Misc fluid top off
I hope it survives the payments, or until the class action lawsuit pending covers this particular engine
I'm verifying it has the KSDS update, so that hopeful it throws a P1326 before it seizes
5 minutes of the Motor Medic, I doubt it helped much, but for $5 I can say I tried something
Pause for rain
Remove factory crush washer
The original PCV rattled, but just barely
We'll see if the B/A part holds up
There was a large chunk obstructing the valve barb, but the rubber hose was clear
5.5qts of Total 5w40 gets it exactly to the full mark, hopefully I'll be able to ascertain oil consumption in a weeks or miles per qt measurement
He was educated on dipstick reading, using Trip B for monitoring, and I sent him away with 5qts of something to get by until warmer weather
Is it the best oil for a healthy GDI engine?
Probably not
Is it LSPI safe?
Doubt it
It's better than whatever it's been getting
92k on factory plugs
Crusty was an understatement, it wasn't worth the OE Double Iridiums
Iridium IX will due, this was a budget job
Intake POV, the TB was fairly dirty
Nasty and not enough was the oil situation
When it showed up
When it left
I think it sounds better, and it survived my mild Italian tuneup test drive
It's on borrowed time, but it's some palliative care to keep it going, and possibly presentable should an engine warranty be available
I kept to a budget, this was $100 and 3 hours of my Saturday
We'll see how long it lasts
Hyundai's website gives you all the info on recalls and service campaign completion
Kias website does not
Does anyone on the forum have a source or connection that can run a VIN, I'm very curious if it's CPO or if it's had an engine, or if the KSDS update has been performed?
I would very much appreciate it if possible
