Probably a good time to dump it and install new oil.
Agree, fairly certain Ford FF is Motorcraft oil which last I checked was made by ConocoPhillips."partnered" doesn't mean "use" (at the factory or in branded bottles). It can be nothing more than a marketing agreement.
The owners manual for Ireland for my wife's previous car had a couple Castrol logos in the oil section, says Castrol oil is "recommended", and included a reference to the engine "being designed with / for Castrol oils".Ford recommends Castrol oil and even sells Castrol through dealerships outside the USA. Ford worked with Castrol to develope a specific European spec oil for the 1.0L EcoBoost engine.
That’s the entire fiat division
Conoco Phillips, 66Pretty sure Honda factory fill is idemitsu.
Conoco Phillips, 66
The early oil change is not so much to clean out remaining break-in debris, something that's highly dependent on the manufacturer and how much effort they put into that, but to clean out the dirt left over from the manufacturing process itself. You would think that engines are made in this clean-room like environment. Far from it. I like to do 2-3 early oil changes when I get a new vehicle. Even that is not guaranteed to remove all the dirt.Yeah, I left my thoughts on this in the thread about early oil changes in a new car. Bottom line, does it hurt to do that? The environment, yes. The car, no. Does it really matter for longevity? I see no proof of that anywhere....
Interesting that they list Subaru; there’s been lots of info that Subaru oil is Idemitsu and UOAs have been loaded with about 700-900ppm moly. I don’t think Castrol makes an oil with that much moly; if they do it’s not something they sell OTC. Which would be odd IMO.On Castrol's site they proudly list being partnered with the following OEMs (https://www.castrol.com/en_us/unite...er-with-castrol/castrol-oem-partnerships.html):
Honda
Volvo
Ford
Jaguar
Land Rover
Renault/Nissan
Subaru
Toyota is tied to Exxon-Mobil and BMW switched from Castrol to Shell fairly recently.
What are the other OEM partnerships?
Castrol doesn't make that, and I doubt they ever will. Even their "custom" oils that are brand specific are just tweaks of their mainstream products. The problem with putting so much Moly in motor oil is that Moly creates deposits. So you have to formulate it in such a way that it cleans up after itself, and it does so exceedingly well.I don’t think Castrol makes an oil with that much moly; if they do it’s not something they sell OTC. Which would be odd IMO.
Here is the rest of that news release which you must have missed.Conoco Phillips, 66
I think you've made your point from your very first response to this thread. Not sure why you aren't just moving along if the thread content isn't what interests you.From a pure marketing perspective, it makes sense for a lubricant manufacturer to advertise that they are the "factory fill" for a premium brand or a particular high-end vehicle. Usually, the lubricants used in those vehicles are high-quality formulations.
However, I couldn't care less what bottom-shelf lube came in my barely-affordable econo-box. It's goind to be drained and filled with some high-quality barely-affordable motor oil, and then life goes on.
what exactly is a premium high end brand vehicle? Hyundai states they use Quaker state, there's nothing spectacular about Quaker state SOPUS oils.it makes sense for a lubricant manufacturer to advertise that they are the "factory fill" for a premium brand or a particular high-end vehicle. Usually, the lubricants used in those vehicles are high-quality formulations.
Cadillac, BMW, Mercedes (their respective premium and high-end models). You don't care what's in your run-of-the-mill C-class, but the factory fill for an AMG vehicle is of more interest.what exactly is a premium high end brand vehicle?
