If the sole criteria were the longevity of the engine then I’d agree. But that isn’t it. We’ve read in CAFE award letters exactly what and why an owner’s manual lists an oil and it is for one singular reason. If that’s also your singular reason then go for it.
Lawd have mercy... Y'all are silly sometimes! Who in their right mind uses anything less than Pennrite 25W-70?!? The perfect 4 season oil for any engine and climate! Period!
If what you're saying is that thicker grades exacerbate that problem, the issue is that all oils are too thick at startup, even 0W-20. All modern oils with reasonable Winter ratings like 0 and 5 are going to be totally fine though at startup and for those first 20 minutes. Also, consider that when an engine is cold you get more piston to cylinder wall clearance right, so piston slap can cause wear too. There's more to engine wear than just oil weight.Great, then maybe someone can explain why every real world study shows that the vast majority of engine wear takes place in the first 20 minutes of engine operation from a cold start...
Literally everyone I know who take their cars to 300,000 and beyond have done it on bulk quickie lube changes. But us BITOG folk are a very unique breed!
AEHaas speaks the truth![]()
Man that filter even looks old school! There's some things I'll never buy online, and filters are one of them. I'm not a fan of online shopping at all, unless I'm actually looking for something used and antique.Probably true but a lot of people I've known that have had their engines blowed up was a result of a quickie, quacky lube error. I worked in one a long time ago, my shop only ever lost one engine for an insurance claim by putting the wrong (but visually identical, same size) oil filter (I think it was a Puro made VW filter on a GM) and the guy kept going until the engine barely ran with plumes of smoke going out, FTR I wasn't there at the time and this over the course of thousands of oil changes using Purolator-made "Group 7" oil filters and mainly Quaker State, and later Valvoline products. We did a lot of Mecedes, BMW's, and Porches and had a following as well using mainly Mobil 1 as we were lest than a quarter of what the stealerships charged...
Somebody is selling this badboy on Ebay, but the buyer should know this filter is at least 20 years old!:
It's not just vapours, it's a combination of several factors:The issue is caustic, acidic vapors building in the crank case at idle and yes thinner oils will remove them slightly faster initially. That's why excessive idling is foolish along with fuel washing the cylinders. But 0W-20 certainly cranks over noticeably easier than even a 5w30 in very cold, say sub-20F temps. Also, I think the oil reaches optimal op temp and deploys the additive package faster on a xW-20 in cold driving where 5w30's are more dependent on polymers and take longer to reach optimal protection. Modern oil pumps may mitigate differences somewhat but there is difference in startup flow, just not enough to cause significant wear either way. Just like modern cars have oil-coolers that keep ambient temps under control and there is virtually no discernable differences in wear at temperature even in hot summer climates using modern formulated oils because the cooling system is probably really the most important thing and is often ignored along with transmissions and gearboxes...
1. Parts that don't fit properly
2. Excessive start-up enrichment
3. Poor atomization
4. Poor combustion
5. Heat-activated additives that haven't reached activation temperature
That's why calling it "startup wear" is a misnomer. I believe @kschachn touched-on it earlier in the thread, but it's really warm-up wear, and it's a period during which the engine is working toward getting normalized, and while in that state, wear is elevated.
BTW, a heavier oil will be heated more quickly; will generate more heat, due to the shearing action of the pump and bearings. It has nothing to do with the polymers.
If you are on the pump relief, yes, there is a difference in flow, if you aren't, there isn't.
As you noted, the fitment of oil/coolant heat exchangers has been a huge improvement, bringing oil up to temperature much quicker and keeping it where it should be. This also aides in facilitating the use of thinner oils by controlling viscosity through temperature.
How does that happen?I agree it is a combo, but the vapours directly correspond with 3 of those 5 points and has been the main reason that oils in the past turned blackish over time. Thicker oil may heat up a bit faster but doubt there is a noticeable difference between a 0W-20 and a 5W-40 when moving onto the highway. Of course all modern oils have additives to fight acidity, but I think excessive cold idling, where I often see literally drops of water coming out a tailpipe in a car in front of me, is probably the single biggest cause of wear....
Oils change colour for a number of different reasons, one of them is carbonaceous materials as a result of incomplete combustion, this was very common with carburetors. At the same time, yes, you have the other nasty byproducts of this process (including the vapours you mentioned) making their way past the rings into the sump.I agree it is a combo, but the vapours directly correspond with 3 of those 5 points and has been the main reason that oils in the past turned blackish over time. Thicker oil may heat up a bit faster but doubt there is a noticeable difference between a 0W-20 and a 5W-40. Of course all modern oils have additives to fight acidity, but I think excessive cold idling, where I often see literally drops of water coming out a tailpipe in a car in front of me, is probably the single biggest cause of wear....
You and me both. I also agree that most folks (other me and me previous Santa Fe Sport 2.0T) i know with very high mileage used whatever bulk or cheapest conventional they could find. Granted, i don't know anyone who's reached 400K. 250 to 300K would be the max.Man that filter even looks old school! There's some things I'll never buy online, and filters are one of them. I'm not a fan of online shopping at all, unless I'm actually looking for something used and antique.
I'm curious . How many people do you know that had an engine blow up because of a Quick Lube place ? I've never met one myself . I've read a lot of stories on the Internet though ...Probably true but a lot of people I've known that have had their engines blowed up was a result of a quickie, quacky lube error.
You mean yet another seagull post?I defended Dr. Haas in a thread several weeks ago, but what is it with people who start a subject known to cause controversy, only to go silent after their initial post?
It’s like throwing meat in front of a pack of coyotes and then standing there so you can watch them fight over it.
Scott
The oil is basically generating its own heat through shear and reducing in viscosity because of that fact, there may be some equalization that takes place if we are doing a comparative, as a thinner oil will obviously start out at a lower viscosity but generate less heat and subsequently thin less quickly than a heavier oil that starts out at a higher viscosity but generates more heat and subsequently thins more quickly.It is heated quicker if the conditions are the same. However, with a thinner oil you can go harder on the accelerator sooner.
In practice heavy may not have an advantage in terms of warm up time.
My Prius has reached 230K using over the counter oils (majority of M1, but I have probably used most of the major brands), but for most of that time, I changed at 1/2 of the OEM interval.You and me both. I also agree that most folks (other me and me previous Santa Fe Sport 2.0T) i know with very high mileage used whatever bulk or cheapest conventional they could find. Granted, i don't know anyone who's reached 400K. 250 to 300K would be the max.
