virgin, it will be a "low ash" out of the bottle.Do you think when Generac says their oil is low ash, do they mean the virgin oil, or used oil?
I assumed it meant virgin, but I'm new to understand oils.
I have not seen one, though there is a 5W40 in the database.Has anyone done a Fram 0w40 VOA? I have some single quarts so I could send in a sample.
Thank You
Do you have a link to the origin of this? Also, more context would be helpful, such as sample/analysis date.
I started this awhile back here: https://bobistheoilguy.com/forums/threads/collection-of-20-weight-api-sp-voas.342292/
and here: https://bobistheoilguy.com/forums/threads/collection-of-xw-30-api-sp-voas.343019/
My time no longer allows me to keep it updated the way I'd like. Plus, people were asking for a downloadable version anyway. So I had the idea to convert it to a Google Sheet that certain people could be given permission to edit/update, and everyone could view and download as a local spreadsheet. Thoughts? Suggestions? Anyone interested in helping keep it updated?
One thing I'd like done is for the VOA threads listed on this sheet to be chased down and linked to the sheet. Any volunteers would need to be familiar with editing Google Sheets, as it could be mucked up pretty quickly otherwise.
Here is a link to the sheet as it stands. I've included separate tabs for 20, 30 and 40 grades. It can be improved (info on certifications can be added if the oil is not API SP, SN+ or SN) and I'm sure there are a bunch of other great ideas you guys can come up with. Let this thread be a place of discussion. If there's enough interest and it becomes a solid single source of VOAs, the mods may decide to make a sticky thread for it. If not, it can die a slow death here.
Link to VOA Database
That appears to be sold as a racing oil 15w40. It doesn't have any licenses. Interesting!
Compared to my SN EP UOA this SP has less calcium, magnesium, & no moly. If there's anything better with the SP it must be the base oil but even then the Oxidation is the same 11. The spider web chart says SP is better but I don't see it LOL. Thanks for finding this though & it's real helpful. Think I'll run it next.Mobil 1 ESP SP from Russian oil club.
Is this oil for generators, or vehicles? If it's not an oil intended for passenger cars, it may not be well suited to add to this database. Their website makes it seem as if it is a generator oil. And the additive package does not look like it's intended for passenger cars.Not sure the process, but wondered if someone could update the spreadsheet with the attached VOA of Generac 5W20 oil from Blackstone?
Thanks,
Chris
It is intended for Generators, marketed as a "low ash" formula, which supposedly works better with natural gas or propane.Is this oil for generators, or vehicles? If it's not an oil intended for passenger cars, it may not be well suited to add to this database. Their website makes it seem as if it is a generator oil. And the additive package does not look like it's intended for passenger cars.
I like Oil Analyzers because they include TBN and Oxidation. They also use gas chromatography which is nice on used oil analysis.Excuse my laziness, but what is the preferred testing facility for VOA? There are a couple of oils I am interested in and previous tests done on them are over 2 years old and so I am sure reformulations have been done since! So would like to contribute to something that I have looked at many times since I have discovered it!
Also, is there a particular method you all go about before pouring the sample? Shake the bottle and pour immediately, shake and then wait 5 minutes, etc?
Could you point me to the info on Gas Chromatography method with Oil Analyzers? I couldn't find this info on their website.I like Oil Analyzers because they include TBN and Oxidation. They also use gas chromatography which is nice on used oil analysis.
I'm not sure it makes *any* difference, but I do shake oil jugs gently before pouring a sample.
https://www.eoilreports.com//testPopUps/fuel-dilution.htmlCould you point me to the info on Gas Chromatography method with Oil Analyzers? I couldn't find this info on their website.
I was interested in Fuel/Oil Dilution, and Oil Analyzers say they use the FTIR method.
Thanks,
Chris
