The only point I was making here is that you are making a downright incorrect assertion about owners manual calling for a winter oil and a different summer oil. Your original post asked the (fair) question, and I paraphrase, that if it is very, very hot outside, should that inform my choice of oil. Generally speaking, a car in proper operating condition will maintain a constant engine temperature without much impact from the ambient temperature. This makes sense, when you think about how thermostats operate in the car’s cooling system. I suppose that if a car cannot stay at an acceptably low operating temperature, the car should be turned off. That said, modern cars are tested in the arctic and in Death Valley and like places around the world. As is so often the case, if you do what the owners manual says, you’ll be fine. There are many folks on BITOG who advocate thicker oils, pointing out HTHS and MOFT advantages, and with the allegation that CAFE standards force the manufacturers to go thin on the oil at the expense of engine durability. That is an interesting and complex ongoing discussion. Another issue is that oils have an appropriate Winter rating to allow the car to start with rapid lubrication in ver cold temperatures. My strong suggestion is to think less, follow the manual and to read the responses in this thread a little more closely. You might benefit from tighter OCIs.
You keep twisting things and trying to find errors or "incorrect assertions" by dissecting and taking things out of context ... This is not a courtroom!
And
I'm really NOT interested in your opinion or strong suggestions and never want to "think less" and blindly follow an owner's manual that is different in the US (in my example Texas) than Mexico. I leave "thinking less" for you! Because I think more and ask why are the two owner's manual different? And the only logical explanation that I've learned from bitog is CAFE.
