I just wanted to make this topic to show you guys this new victo foam gasket i picked up. It's made by victor reinz. This specific one is for my thermostat housing. In the past i've used those regular paper fel-pro gaskets with less than stellar luck. Maybe it was my application method, i have no idea. They worked but i would always notice some seepage in the area. It was small enough that it would evaporate on the manifold but just enough to aggravate me. I replaced my upper hose, lower hose and thermostat, using the foam gasket on the housing. I'll honestly say this is one gasket i have no doubts about. When the housing was torqued to spec, the foam compresses just enough so that you get a positive seal. I'm happy with it, and at $6 it's worth the peace of mind.
Here's some pictures of it. If anyone else has two bolt housings and wants something that works, this is for you. Auto zone was the only place i could find these.
I sure wish i could get VR to custom make some of these in other applications. No more RTV or worrying about anything.
