Some potentially helpful info...
"The Taurus SHO V6 pump is rated at 12.1 GPM at 43 PSI at 6400. Since output is near linear for the positive displacement internal gear, one could approximate this as 2 GPM per 1000 rpm. Pump specifications for the V8 are absent but assumed to be similar if not slightly greater."
http://www.shoclub.com/lubrication-oil/lubrication-oilpart1.htm
Engine displacement for the early-90s SHO V-6 was 3,153cc, a mid-sized engine these days. For purposes of this filter survey, I'll go way, way out on a limb and suggest that a lofty goal of 12 gpm/min @ 45 psi filter flow might be reasonable for the "average" sized sporting or DOHC engine, barring actual data on your specific oil pump (oil pump flow spec's are tough to come by). Differing opinions are welcome -- I'm sure I missed something somewhere...
Also, the report mentions "for simplicity I used 1 gram = 1 milliter." If this might affect the test results, Kendall pegs their 30w oil at "0.875g/cm3," which is the same as 0.875g/ml -- perhaps you were already aware of such a spec.
Using the "oz/sq in/min @ 20 psi" column, I come up with the following media flow rates at 20 psi...did I interpret your methodology correctly?
PureOne (330 sq in): 1.6 qts/min
STP (326 sq in): 3.8 qts/min
K&N (343 sq in): 4.7 qts/min
I'm at a loss as to how this jives with the Baldwin/Hastings claims of "12 gpm @ 16 psid." Either I'm missing something basic, or perhaps they're including bypass flow as well...? (Some time back I came across a website that mentions Frams as having "3 gpm bypass valves," so this might be a good rule of thumb for competitors' similarly-sized plunger bypass valves.) Geez, I need a couple beers after all this...
[ January 28, 2004, 08:02 PM: Message edited by: TC ]
