Vaseline on battery posts and cable connections?
N.C.
Back in the day many people would put a thin coat of petroleum jelly on their battery connections to keep corrosion at bay. I’ve personally never used it but on my wife’s new/old 2008 Pontiac Solstice GXP with the 2.0T the negative battery cable connection was corroded so bad I ordered new cable ends. I remembered that mechanics and diyers swore that Vaseline would help fight terminal corrosion but with the turbo and extreme under hood temps I’m thinking it would just melt away after a few drives. Is there any modern alternatives to Vaseline available today or might the Vaseline actually work in this hot environment?
Maybe when cars ran 160° thermostats if any, and underhood temperatures were a lot less. That grease I would think is an insulator, so could melt down between the battery cable and the battery terminal causing many problems. Get stuff specifically made for that purpose.
About 40 years ago I bought a battery at Sear's Roebuck and they used the Permatex sealer above.
My battery posts/clamps stayed perfect for YEARS. I went out and bought some and never looked back.
That was so long ago I've gone through cans which were dyed red, purple and green.
I've nothing against any other product which works but I needn't think about it.
The Permatex does not attract dirt in my experience.
I’ve used these at home and they’re REALLY similar to the BG pads I’ve used at work. They’ve been very effective at preventing acid leaks.
Quite a price difference too as the BG kit is 29.99 and the noco equivalent is $10. If you don’t need the cleaning solution(you really don’t, baking soda and water still works best), then the pads alone are $1 from noco.
How could there be grease between the terminal clamp and the terminal post if the clamp has been tightened properly?
Try SEARCH. There are several threads on this topic, having answers to your questions.
For example
I did…..but I also wanted to address the heat under the hood and was wondering if there was a product that could take the heat from the turbo without melting away, as well as addressing the corrosion problem.
Yeah advance auto parts and auto zone have a spray that coats the terminals. Really seems to help
I have used Vaseline on all car batteries. I would also take our car periodically to the drive-through Exide service center in the city I grew up in, and they would check the batteries, top off the cells with distilled water and coat the terminals with petroleum jelly, all while I sat in the car. A small tub of Vaseline is in my garage as well. Cannot go wrong with it. The smallest tub will last several years.
Why does oil leak from a properly tightened drain plug? The parts don't fit together perfectly at microscopic levels so the grease will migrate into the space.
Aka vaseline in a can with solvents and propellant.
https://www.permatex.com/wp-content/uploads/sds/80370.pdf
A little more than that. And I think I would use something designed by the chemical engineers at a Fortune 500 company made specifically for one purpose over something grandma uses to moisturize her lips.
No it is not a little more than that. Propane is the aerosol propellant. Petrolatum is petroleum jelly. Acetone, Xylene, Ethyl Benzene and Toluene are organic solvents used to emulsify the petroleum jelly and to act as the liquid carrier for the aerosol spray. Once the aromatic solvents evaporate, only the petroleum jelly remains on the battery terminal. Simply a more convenient application method than a Q-tip.
If it leaks into a space between the terminal and the clamp then there is already a dielectric in that space (air). There’s no conduction anyway. It’s a complete non-issue.
Dielectric grease typically. I also have spray protectant at home too. The spray doesn’t last long the dielectric grease does. I work with some old timers who use anti seize on the terminals but I can’t see how or why that would be a wise thing to do.
I've seen some sort of brownish looking, translucent grease on my Integra. When I replaced it I got a battery at Sears and they also sold me some sort of red spray to put on the terminals. It was nasty stuff including MEK as a solvent and when I got it on my garage floor (should have spread out a newspaper) I couldn't clean it off.
Other than that, I some Victor branded purple battery terminal grease. But these days I leave the battery terminals naked.
