That's the stuff I use, though the exact product I have comes from East Penn. Colors the posts/terminals red, always seems to work well. I've never had a corrosion issue on terminals I've sprayed it on.After you get them clean use some protectant.
Amazon.com: CRC 05046 Battery Terminal Protector - 7.5 Wt Oz. : Automotive
Buy CRC 05046 Battery Terminal Protector - 7.5 Wt Oz.: Electrical Cleaners - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
I dont have corrosion issues unless I use exide.
Most likely you will need to reset radio stations and some other settings(possibly).
However, vehicles such as certain GM will hold stations. Check both posts really well while your at it and as long as you’re disconnecting one, do the other.
Also apply something on the posts & terminals. Lot of different opinions on what is best to apply.
If you have removal caps, check the acid level.
Some folks use regular grease.
Others use petroleum jelly/Vaseline.
I use dielectric grease.
And others use an actual battery spray or coating.
What's odd is my Jeep's did it on the negative terminal, while on a Noco Genius 1A charger for 4 months...Neg(-) post/terminal corrosion means under charging.
Pos(+) post terminal corrosion means over charging.
Keeping a battery maintainer/tender on the battery will help to reduce or even eliminate sulphate buildup on posts & terminals.
Unfortunately IDK!What's odd is my Jeep's did it on the negative terminal, while on a Noco Genius 1A charger for 4 months...
You want to explain the logic of that statement? ............... I am sorry but my dunce cap is on again and probably too tight making me unable to reason whyNeg(-) post/terminal corrosion means under charging.
Plug a memory saver into the 12V lighter socket/power outlet before disconnecting the battery. This works only of the oulet does not run on switched power. Otherwise use a battery saver that plugs into the OBD port.Noticed some corrosion on negative post. Can I just disconnect the negative cable and clean the post and cable? Will preset radio stations need to be reset?
