My daughter left a light on in her Prius which ran down the battery. She was able to jump start it and go to work. The battery is an Optima that I installed a few years ago. I open up the back to get to the battery and was shocked to see corrosion on the negative terminal. I thought this battery was sealed and we would never get corrosion from battery acid. I know there is a water leak back there but that should have no effect.
The negative ground post is odd. It looks like it is cracked. Could it be hollow and leaked out battery acid???
One more question. I usually replaced the terminals on all of my cars. The negative terminal has corroded so much but it is much smaller than most terminals on my other cars. Can I get a new smaller terminal to fit that?
