Valvoline Restore & Protect
Yes, see post #1981. I’ve switched all my vehicles plus the ones I maintain to M1 ESP 0w30. In 2018 when I bought my new Outback I believed 5k oci’s with any full synthetic oil would keep my pistons clean, I was wrong. My next new vehicle will get HPL, Amsoil SS or M1 ESP(if it passes my test) at the first oci.
Now that I've posted the Valvoline Euro 5w30 xliii, what do you see about esp better than that? The approvals of the xl iii seem pretty darn good.
It looks great! Appears very similar to ESP 5w30. I use the ESP 0w30 because it still uses the ester formula and I’m hoping it keeps pistons clean. And it’s at my local Wally.
I do look forward to your results with the Valvoline xliii!!
Currently use M1 5W30 ESP and engines I care for as they like it . I’ve always used M1 , Valvoline or SOPUS synthetic 5W30 oils at 3K to 4K mile / 6 month OCI’s , so maybe I’ll only need 2 or 3 VR&P OCI’s to ensure my engines are clean , then switch back to M1 0W30 ESP.
For my oil consumption it took 3 oci’s before I started seeing an improvement. I’d recommend 4 oci’s minimum just like Valvoline recommends.
I have noticed there is of course some confusion about the interval for how long to run VRP and it got me thinking
If VRP had stated to run the oil for 3000 miles or 4000 miles then the general public would treat it more as a “engine treatment” and not a proper oil
This would of course generate way less sales as oils that are in the same price range are all touted to hit 10k miles at the minimum
More on, if VRP says to do 10k miles then once again that isn’t a safe comment as there could be a heavy fuel diluted engine that runs it to 10k and then causes engine damage etc
That is why it is most safe and why also VRP formulated this engine oil to be “follow manufacturer oil change intervals” as they want it to compete with normal drain intervals as it’s competitors but also be able to clean and restore at the same time
Maybe this was discussed already and of course I don’t have any facts just making an educated guess. So for anyone wondering how long to run VRP, run it for how long YOU want to since Valvoline definelty isn’t going to come out to say to run it for 3k miles or 4K miles. They formulated this oil to run just as long as the others. (I tbh was in this group too but as I thought about I know now that I can run it for whatever interval)
5k oci’s. 19k miles total so far.
So, for your vehicle, you were past 10k miles of use before the consumption noticeably changed? Seems about right for a gentle cleaner. I’m planning on using it this fall for a similar approach of 5k mile intervals; and will be patient as their claims suggest and verified by yourself. I have 340k miles on this Honda so it could take longer 🫣😂
Yes. I almost gave up to be honest. No oil consumption change at all for 2 oci’s. Slowly dissolved piston deposits imo.
What was the oil burning rate before the VRP use was started? I'd think if it was really burning a lot due to stuck rings, then the longer it will take to free them up with a mild cleaner like VRP.
It isn’t confusing at all. Everybody says follow manufacturer’s recommendations. That’s the default answer.
Just over 1 qt per 2k miles. Almost 3 qts in a full 5k oci, 5 qt sump.
That gives me hope as my 07 Fit is at around half that rate; 1 Qt / 4k miles.
Looking forward to your full review. :)
What was the total mileage on your vehicle when you began the series of OCIs? If you don’t mind spoilers. 😅
Which Honda motor? My r18 with 236k at the time lowered its consumption of oil from 1/2-3/4 quart per oci to nothing in 2 changes and was almost spotless after 4. 5k intervals
Any concerns to running EC30 with VRP ?
Could have two different chemistries trying to accomplish similar things; which has unknown effects on its behavior as no one has tested them in a controlled setting. HPL has said their oils clean better than the EC.
So, I view the EC additive as something to add near the end of an OCI on a run of the mill generic synthetic OTS at WM etc. HPL has suggests its use prior to converting to their fully formulated PCMO as a prep.
The possible canceling effect of running two different types of cleaners at the same time; are just as likely as improving each other during concurrent use.
Why not try VRP on its own and then consider EC if you don’t get the results you are looking for?
I wonder if the deteregency of the synthesized base oil of the R and P would clean up the gummed up rings of a known oil burner like the Toyo 2.4 or later Honda K24's?
